Upgrading Audio system in EcoBoost Lariat B&O
jayhawkcole
Cole
Kansas City
2024 Maverick Fx4 Lariat
Pictures at the bottom. I provided WAY too much detail in this post but compiling all I know in one place in case someone is in a similar spot as me someday, hope I can help that person!
This forum has a ton of posts regarding upgrading the stock Mav stereo system but only a handful regarding the Lariat B&O system. As others have stated, I agree that from a clarity perspective, the B&O system is pretty adequate (the rears are ass but not worth the hassle given their awful placement). That being said, I have always found the B&O system to be too quiet, as well as having actually laughable levels of 'bass' (the stock B&O system has a 6x9 infinite baffle 'subwoofer' behind the rear seat). However, the biggest sin of the B&O system is the bass rolling off at around volume level 22-ish, which compounded the lack of overall volume issue to me. So with that context, I decided that I wanted to upgrade the stock system, but wanted to do so in such a way that it could EASILY be returned to stock for any reason at a future date and by any party, as well as somewhat cost effective (aftermarket audio is never exactly cheap).
Below are the the parts I used to frankenstein together an upgrade to the stock B&O stereo for ~$900 (including taxes).
As is, the stock B&O amplifier powers the 6x9 'sub', the front door speakers, and the front tweeters. The center channel and rear speakers are powered by the head unit, to my understanding. Since the door speakers are the primary source of mids and highs, I planned to focus my efforts there for the speaker upgrades, leaving the rest mostly untouched.
My plan is to retain (but unplug) the 6x9 which will keep the hole in the body from being an empty cavasse others have complained about, and retain the stock amplifier, passing all signals through it, but only actually utilizing it for the front tweeters (a waste but allows for easy reversing at a later date if needed).I utilized an AudioControl LC2i Pro which I fed a signal from the subwoofer outputs out of the stock B&O amp going to a monoblock amp, and the stock B&O speaker outputs going to the high level inputs of two channel amp. This proved to be a wise setup alllowing me to independently adjust gains independently between the sub and front door speakers, as well as retain all stock fade/balance controls as well as the stock high/mids/bass controls in the Headunit. I have purchased the Skar Audio loaded box to live under the rear seat and to be powered by the monoblock amplifier, and have purchased a set of component speakers for the front doors that will be powered by the two channel amp. I will mount all this behind the rear seat and retain the factory wiring using male/female spade connectors on both the factory and aftermarket wiring to allow easy connecting between the two systems (and reconnecting of the stock system back together in just minutes if the aftermarket equipment is removed.. The component speakers come with small tweeters that I will replace the stocks with (thingiverse adapters to mount these tweeters into the factory locations) (still powered off the factory amplifier).
I cut up an old cardboard box and used it to quickly design a template for the amp mounts behind the rear seat, then transferred that to a 1/4" sheet of plywood and wrapped that in some black felt. This allowed me to build most of the system from my workbench rather than breaking my back bent over in the backseat except when I had to be (like when tapping into the speaker wires coming out of the factory B&O amplifier and running the power wire from the battery (ran it through the provided wire channels along the driver side door sills).
The addition of the small two channel amplifier for the front doors has proved to be a MAJOR upgrade. Honestly, it can be WAY too loud and I used the amp gain to turn it down fairly significantly, setting it to be just a little bit louder than stock (which is what I was after). In addition, the subwoofer also can provide far too much bass but sometimes that is fun! I ran a discrete bass knob to next to the drivers seat for easy adjustments, as needed. Overall, this project probably took me around 8-10 hours between the various sessions from start to finish but everything works and despite the stock B&O system having pretty adequate clarity, these aftermarket component horns in the doors are MUCH clearer. I am pretty thrilled with the result and how modular everything is (I could have this all uninstalled and back to stock in under an hour, easily).
Full disclosure, I cheaped out a bit on the amps, but they both actually have good reviews and Im not going to be pushing them anywhere near their limit. If one of them dies someday, I can always swap it out fairly easily.
Parts list:
$786 total (before taxes), and maybe another $50 in odds/ends for connectors and such.
Pictures below!
  1. The starting point, stock B&O system
    1. Ford Maverick Upgrading Audio system in EcoBoost Lariat B&O IMG_9934
  2. Using cardboard to figure out the maximum room I had available. This was just simply trial and error.
    1. Ford Maverick Upgrading Audio system in EcoBoost Lariat B&O IMG_9938
  3. After I felt comfortable with my template, I transferred this to some scrap 1/4" plywood I had laying around. When I cut the plywood to shape, it splintered the veneer so I covered the edges in duck tape just to avoid splinters. Didnt mind the appearance since I planned to wrap with fent regardless.
    1. Ford Maverick Upgrading Audio system in EcoBoost Lariat B&O IMG_9963
  4. The final trimmed look set in place. I put some blocks at the top of the two highest points to provide clearance for the stock wiring that would still need to be there behind this panel.
    1. Ford Maverick Upgrading Audio system in EcoBoost Lariat B&O IMG_9958
  5. The look after I wrapped and stapled in the felt
    1. Ford Maverick Upgrading Audio system in EcoBoost Lariat B&O IMG_9965
  6. At this point, I started wiring in the components and screwing them into this board. I didnt want a bunch of screws sticking out the back so afterwards I went back with a cutoff tool and knocked everything (mostly) flush on the backside of the board.
    1. Ford Maverick Upgrading Audio system in EcoBoost Lariat B&O IMG_9971
  7. For those of you that get the joke, now is the point where I tell you to 'draw the rest of the fucking owl'. No magic to it, just putting wires where they go and finding space on this panel wherever I could, keeping it as reasonably neat as possible.
    1. Ford Maverick Upgrading Audio system in EcoBoost Lariat B&O IMG_9993
  8. At this point, I switched to the part I had been putting off for a variety of reasons and started snipping the speaker leads. I tapped into leads 6/16 and 7/17 for the front speakers (6 and 7 are the negatives, 16 and 17 are the positives). One set of leads would go out of the factory amp and into my amps, and then the other leads would take the output of my system and utilize the stock wiring to run the signal to the new door speakers. For the sub, I just ran a short wire to the sub directly below the monoblock amp on the right.
    1. Ford Maverick Upgrading Audio system in EcoBoost Lariat B&O IMG_9988
  9. At this point, I pulled off door panels and put the new door speakers in, as well as dropping that Skar audo box into the rear seat tub. Everything fit well (crutchfield sent adapters for the speakers).
    1. Ford Maverick Upgrading Audio system in EcoBoost Lariat B&O IMG_9980
    2. Ford Maverick Upgrading Audio system in EcoBoost Lariat B&O IMG_9985
  10. Finally, i loaded in my finished amp/component board and hooked everything up which was easy given the male/female taps located in their appropriate locations and everything worked the first time. From here, it was just a matter of setting levels and gains on the various components to dial in the sound. Works great!
    1. Ford Maverick Upgrading Audio system in EcoBoost Lariat B&O Untitled design
    2. Ford Maverick Upgrading Audio system in EcoBoost Lariat B&O IMG_0005
    3. Ford Maverick Upgrading Audio system in EcoBoost Lariat B&O IMG_9978
CV60MAV
NKY
2025 Mav Lariat Hybrid
Holy cow Batman
great detail love it saved
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
You run your volume level at 22? You must be either totally deaf or trying really hard to impress the schoolyard a block away..
jayhawkcole
Cole
Kansas City
The audio level from Carplay is (and always was... stock) lower than both the radio and bluetooth inputs. I am not sure why, but either way, my wife also agreed it was a bit too quiet, especially on the highway and/or with windows down. 🤷‍♂️
jayhawkcole
Cole
Kansas City
12v battery not impacted! All good here. The cars alternator has plenty of overhead.
Toddman45
St. Louis, MO
Congrats all the factory stereos in the Maverick don't sound that great. Aftermarket speakers and sub are a huge improvement, especially if you enjoy listening to music as it was intended.
It also helps to add a little sound deadening inside the doors and on the floor, roof as well if you're dedicated.
Ford Maverick Upgrading Audio system in EcoBoost Lariat B&O efddffe4-33c3-41fe-baa5-a7b8fa3e3b18
Ford Maverick Upgrading Audio system in EcoBoost Lariat B&O 598f4f39-a3f3-4bf0-ac29-3aba1eb7f0e6
Ford Maverick Upgrading Audio system in EcoBoost Lariat B&O 20241030_151136
Ford Maverick Upgrading Audio system in EcoBoost Lariat B&O 20241116_020459
Ford Maverick Upgrading Audio system in EcoBoost Lariat B&O 20241103_001541
Ford Maverick Upgrading Audio system in EcoBoost Lariat B&O 20241026_122244
Ford Maverick Upgrading Audio system in EcoBoost Lariat B&O 20241207_132033
Ford Maverick Upgrading Audio system in EcoBoost Lariat B&O 20241207_150434
ramrodder
Minneapolis, MN
Acura TL
Do you mind telling how much all-in your upgrade was?
Did you custom make that sub box?
Cancunbadlands
Cancun
Cancun
jayhawkcole
Cole
Kansas City
All my major components I have linked in my first post. All in I was probably near $7-800, but well over half of that money was just to get the subwoofer working, so if you don't want a subwoofer it's much cheaper.
Maverick_Dad
Austin
St. Louis
2023 Maverick XLT
Thoughts on the Skar loaded enclosure? I haven't seen much posted about it yet.
tturby
Missouri
2025 Ford Maverick XLT, 2023 Mustang Mach E GT
I just installed one of these in my truck. I bought the unloaded version and installed a kicker sub. It fit very well but it basically flush with the top of the tray so the sub sits higher than I like. May need to get a grill for it. I went with this because it was advertised as having 0.73 cubic ft of airspace while almost all others are less than 0.5.
Maverick_Dad
Austin
St. Louis
2023 Maverick XLT
Did you go with the Kicker CompRT?
tturby
Missouri
If I didn't already have a Kicker CompVX laying around I would have gone with the CompRT. I may still end up doing that as the enclosure is the bare minimum for the CompVX air space.
vertigo12369
MK7 GTI
How is bin access impacted? I had to remove my ProLineX box as the lower seat cushion would not sit down correctly and the rubber stand offs would rub the box when I lowered it. Eager to get a 10" sub back in vs the 8 I have now.
