Dad
I believe it is a free download, at least that is what I've been told. I haven't investigated further since, I don't own a Windows computer nor do I understand how you get the new coding into the Maverick's computer system.
Neither do I. I've been posting this question on this thread for the past month and have yet to receive and answer (or, I missed it)
Gullzway
OK
1968 Ford Mustang Fastback
Is this a reply to yourself?
Regardless, there is a free 2 month extended license trial for Forscan. You can get it multiple times, no limit as far as I know .
Have a look at their website.
https://forscan.org/download.html
Dad
Oops! Not sure how I managed to do that! I meant to reply to someone who also did not know how to get the forscan codes into the Maverick's computer system.
Thanks for the correction and the link. Much appreciated.
Jackkal22
Kalem
Nebraska
Ford maverick
It is possible that is should work on that trim. Even though it looks like the speed sensors are different from Escapes to Mavericks the functionality should be the same when enabled.
If you have a Lariat Lux, Forscan and a programming cable, pm me if you want to attempt this and I'll walk you through it best I can.
Could you possibly walk me through this?
Jackkal22
Kalem
Nebraska
Ford maverick
Im new to the forescan world I have a lariat lux eco boost was wondering if someone could walk me through how to add this.
Jackkal22
Kalem
Nebraska
Ford maverick
Mabcim
Rochester, NY
I would if you could walk me through this.
I did method 2 from the first post.
I did just these two settings:
IPMA 706-01-01 xxxx-xxD3-xxxxx
(I had a C9 where the D3 went)
IPC 720-09-01 xxxx-xxxx-8xxx
(I had a 1 where the 8 went)
When complete, I had a ’Traffic Sign Recognition’ menu option. In that menu I have ‘Active speed warning’ checkbox and ‘Tolerance’. Under Tolerance I can go to 5mph max. I ended up not checking the Warning option because I did not like how the sign flashes when you go over the limit.
Forscan’s website has details on how to use it:
There are also videos on YouTube you can search for,
cjhart34
Iowa
Maverick Tremor
I try these methods and get this error code when I try to rewrite the highlighted code to a different code provided in this thread. Any advice would be great.
Ford Maverick Traffic Sign Recognition (TSR) FORScan mod (confirmed working) 8BDD2B1B-B071-4297-A326-995E4F0B3F0D
Ford Maverick Traffic Sign Recognition (TSR) FORScan mod (confirmed working) EC8538F2-27EF-4252-BD2D-88E1E0F33A56
Mabcim
Rochester, NY
Did you retry? I had that happen to me when doing some modules. Some took 2 or 3 retries.
cjhart34
Iowa
Maverick Tremor
I tried probably ten times and got the same error every time
Mabcim
Rochester, NY
That stinks. Maybe search the Forscan forums, so see if any else has seen that specific error on other vehicles. I know there were some issues with some versions, so make sure you the latest,
ppagan2012
Paul
Puerto Rico
Maverick Lariat FX4 AWD
When FORSCAN ask to load the saved configuration check NO. Try that.
Bry@n
Bryan
Central NJ
23 Maverick XL, F150, Bronco
Thanks for all the info on this. Just so I understand, if I choose method 1 or 2, I will get speed signs and traffic signs?
I don't want any tolerance info or feedback. The radar detector does that for me already. Or is that a must do?
BlackMav23
MI
2025 Lariat (Shadow Black, 4k Tow, Sunroof)
Has anyone confirmed this working on a US XLT Lux with FX4, 4K tow, and copilot 360?
If so I'd very much appreciate a walkthrough.
