There is no navagation available on the maverick.
There isn't traffic sign recognition available from the factory either, yet here we are. Not impossible someone might swap in an APIM with Nav.
Maverick2022XL
name
hinterlands
Upgrades to the existing Sync 3 on the lariats w/Lux package should be possible. It may already be installed but hidden in the APIM settings. That is for Lariat owners to determine.
bdaniel230
Daniel
Middleton, Id
2022 Ford Maverick XLT -Hot Chili Red - 4k Tow Fx4
In short yes but the last 2 digits in the codes are checksums i.e. xxxx-xxxx-xx** where the * is the checksum values. When you put in the changes it will give you a checksum error. That is okay to proceed since forscan will correct them before writing.
Great to hear. After working with networks and checksums all week I really want to stay away from the binary nightmare that is checksum calculations on circuits I don't have the schematic
bdaniel230
Daniel
Middleton, Id
bdaniel230
Daniel
Middleton, Id
A nav module for Maverick? That's a grand for a module that will need to be introduced into the ECM through Forscan, Fun.
If someone can tell me I can upgrade my non-sync system to any of the sync systems, that would be great. Otherwise I need to wait until a Maverick gets wrecked to find the unit to make mine sync. I had no idea that you had to order the upgrade to get sync
GodFatherofTech
DFW
Mini Cooper, Vette, '69 C10, HD Trike
Got it all enabled. Not only after you do it in Forsan, you have to go into settings and enable it, then turn on the screen.
I guess I am dense. I can't seem to figure out all of the changes needed in easy mode to make this happen.
I have looked at chimes in IPMA and TSR is set to SLOIF. in APIM, I have TSR overspeed enabled.
Unsure what else I might be missing.
GodFatherofTech
DFW
ok. reading and rereading this thread and I have it working, but with round signs. that's fine until I can sort this out. I have US and MPH selected in IPMA.
Thanks, everyone
TrippMe
Tripp
Thanks, everyone
I THINK there are only round signs.
It works remarkably well.
belmor
Ben
Florida Keys
2022 Maverick XLT
I think the round signs are showing up on the FX4/Lariat screen and the square ones show up on the XL/Base XLT screen. I haven't seen a fix to make square signs on the larger dash.
Gullzway
OK
1968 Ford Mustang Fastback
So on a Lariat/Lux to enable TSR I just need to make these two edits?
Enable TSR in Menu:
IPC
720-03-02
xxCx-xxxx
706-01-01
xxxx-xxD3-xxxx
Not interested in No Passing Icon or Over Speed Chime.
GodFatherofTech
DFW
FYI, these signs don't get recognized.
Ford Maverick Traffic Sign Recognition (TSR) FORScan mod (confirmed working) edited_20220317_131041
