Tailgate Open Notification?
HoiToid
I slip a neon yellow zip tie under the protective cover on top edge of tailgate. Just stick it straight in (without any loop) so the "head" is visible in my rear view driver's side mirror. If I can't see the yellow zip tie, then I stop to make sure the tailgate is up.
Sometimes it needs adjusting to keep it visable, but it's a cheap, easy solution.
Backin15
Frozen Minnesota
2025 Maverick XLT
I can see the top of the tailgate spoiler in the rear view mirror. The backup camera is a nice way to check when stationary, can we access it while in motion?
I believe the 24 and 25 model years you can access the camera well in motion.
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
Most pickup drivers have a use for an open tailgate, so it makes no sense to put switches in to check for that. The rear is normally jacked up a bit and tends to make things slide away from the rear every time you hit a bump. Also every time you hit the brakes things will slide to the front, not the back.
BoboysTruck
Virginia
F150, Focus, Juke
Yep , done that.
Me too. I had the bed loaded and practically dumped everything on the road at a traffic light about a mile from the house.
I like what you did there.
I used this that I stuck on the inside of the tailgate.
Ford Maverick Tailgate Open Notification? Screenshot_20260324_181621_Amazon Shopping
I then ran a cable to the inside and used an LED lamp that would light up when the tailgate is down.
Ford Maverick Tailgate Open Notification? 20260324_175856
1Guy1Truck
RI
2022 Maverick XLT
Do you mind sharing the path you followed to route the wire into the truck?
Busa789
Dennis
Iowa
2025 Lariat
Then it's the 2025 with the bigger monitor that you can access the camera while you're driving. Thank you.
Yep. On my 25 I can access the rear or side cameras while in motion. I don't recall being able to use the front one though, certainly for liability reasons.
Maverick123
25 hybrid
*this is only on Lariats with the 360 degree cameras. It's accessed by pressing the camera button
PS going forward at low speed it'll show the front camera view, then above a certain speed it'll switch to the rear view
BoboysTruck
Virginia
F150, Focus, Juke
Sorry I'm just getting around to this.
Ford Maverick Tailgate Open Notification? 1000028569
I ran the cable under the truck after removing the HVB cover. There is an access hole down there that already has cable going into the battery compartment under the rear seat. You can't miss it.
Waterick
Laurens county SC
I have the 24 XLT FX4 and can’t, but if I could, I wouldn’t know how! 🤔
On my '24 Lariat there is a setting to allow the rear camera to continue displaying after being in reverse while going forward, but only up to 5 MPH.
Cancunbadlands
Cancun
Cancun
I forget to take my pills
