Regular or premium gas??
TBoe1776
TBoe1776
2020 Toyota Tundra
Just look at ten day forecast when you buy gas and if temp projected 98+(depending on your altitude and time of day you tend to drive you can tweak when you want to pay for premium) buy the grade you feel will be best. Should get feel quickly which grade you are comfortable with. If nothing else maybe "shopping for which gas you want to buy" will make the price ($7.77??) a little less painful?
Yeah in all honesty, even if I fill up the maverick with premium all the time, it would still save me more money than filling up my 38 gallon Tundra with regular 😂
Down
Jason
Scottsdale, AZ
22 Maverick/02 Z06 Vette
Well, as I said, I have plenty of experience with an Ecoboost and have spent the last 4 years or so deciding what I'm comfortable with. In that time, I've determined that while everyone has their own perspective, mine is that a cpl per bucks per fill up does not bother me at all, checking the weather every time I fill up sounds like a nightmare though. MAYBE if I lived in a place where heat was more random but almost half of the days out here last year broke 100.
I'm under no false assumptions that I'm "saving money" in the end by using premium, but between the moderate increases I see in MPG and the more noticeable pep when accelerating, the miniscule amount of money we're talking about here is A-OK with me.
  • Like
Reactions: Guv
Down
Jason
Scottsdale, AZ
Check the weather every 10 days????!??!!!!
OMG
A person might have to quit their job. I’d bet that would take about 10-15 seconds
Pumping gas without creating a plan and therefore paying an extra $0.30 a gallon?
A person might have to mortgage their home!!!!
#ohnoes
Honestly I put that out to maybe come up with a fairly quick way for someone who has not learned much about many things and now have suddenly been introduced to a fear item that they perceive will surely totally destroy their ride if it "knocks 3 times" and cannot bear the thought (wether they can afford it or not) of spending .30 unnecessarily. So maybe I have given at least one person a small way to not feel as stressed.
Evil2ltr
Kevin
Asheville, NC
2022 Alto Blue Maverick XLT AWD
Boils down to... is 10hp worth $1.00/gal more.
That said, I am also a believer in a boosted 10:1 CR engine using premium. The DI helps with this motor being happy on 87 oct though.
Rodeoman74
Casey
Milliken, Co
2022 Maverick 2.0l Lariat
I plan on running midgrade. It may not make peak hp but it wont knock.
I agree, mid grade is what I plan on running. In CO premium is $.45 more than mid and $.76 more than regular. the only time I might consider premium is the peak of summer. The higher octane prevents pre ignition. most likely wouldn’t need.
Trucklet
D
2022 Ford Maverick XL AWD 4k
The easiest and obvious solution is to install a secondary fuel tank, and a thermostat controlled relay near the fuel pump that decides which tank to pull from based on outside temperature. Fill one tank with high test, other with regular.
I think there's a QRcode for this project in the flexbed, but I can't check because the optional 4th tire was a constraint item due to petroleum shortages and so I still don't have my truck. I shall continue to bide my time by posting nonsense, and I wish you all the best.
Ford Maverick Regular or premium gas?? kermit
Dave S
Portland Oregon
I have never had a turbo motor
Did a tank on regular and new tires. 28.2
Did a tank on premium. (Fill at 1/4 regular). 30.5
Think I will be sticking with premium. Only .30 more a gallon
Nighowl2000
Roy
Ottawa
2022 ford Maverick lariat
I live in canada where premium is $1.60+ a litter (30c more), so ill be using regular unless summertime and +30C or more
kw86er
KW86ER
Vancouver BC
2L XLT FX4
I run regular on everything I own unless it has high compression heads. My street bike needs 91+. The Mav will get regular. Econo cars are designed to run on cheap gas. Also from Canada and I bought this truck to be a cheap run-around.
Darksider
Here
Two
I am surprised no one mentioned methanol injection. This is common running turbo with direct injection where i am from..
Lets you run minimum octane but gives you a octane boost when under load/boost. Plus it helps keeps the valves clean.. But where i am from most of these cars are out of warranty also..
Dechion
Brad
Titusville, Fl
2015 Kia Forte
Are the octane requirements the same for the hybrid? It may be here somewhere but I couldn't find it.
Rodeoman74
Casey
Milliken, Co
No, the 2.5 naturally aspirated I’m your problem running on regular. anything higher than regular on the naturally aspirated would be a waste of money
Shakesbear
J. R.
Running anything more than 87 is just just pissing your money away. AT BEST, you might, might, get an extra two HP. I think the manual says if you're towing a heavy load, then 91 may help. 98% of the time, 87 will be the best fuel for an eco-boost 2.0. I've seen the comment that in the heat, 91 may be better, but I live in Texas with temps near or over 100 degrees for half the year, and I call total BS on that. If you feed it 87 from the get go, it will be just fine ;)
