Premium or Regular unleaded ??
  • Thread starter Deleted member 528
  • Start date
  • Watchers 8
Mainer500
Lou
Maine
2018 F-150 STX, 2016 Ford Fiesta SE
Hi all,
The cost of Regular VS Premium unleaded is almost a deal breaker.I always heard that turbo needed Premium. What fuel does it need? How about Ethanol 10% ?
Thanks
I asked my Dealer service managers and they both said 87 is fine. If I'm not mistaken the Maverick has a twin turbo which alleviates some of the carbon build up of earlier turbos. Anyone hear different?
TruckVille
Washington, DC
Alto Blue, 4K Tow, Luxury Package, Flux Capacitor
I've read a lot of reviews and watched a lot of videos because I'm so excited about getting this truck. Right or wrong, here is what I've found out -
1. The Hybrid has a 2.5 liter with no turbo. The link with the electric motor gives it extra power.
2. The 2.0 EcoBoost has one turbo.
3. Carbon buildup has been in the news, mostly with Toyotas. It's not related to turbos, it's related to where the fuel injectors are located.
4.Carbon builds up on intake valves when an engine uses direct injection rather port injection. The reason is that port injection shoots fuel over the intake valves and this keeps them clean. Direct injection shoots fuel directly into the cylinder, and the result is that the intake valves don't get cleaned by the fuel and carbon builds up on them.
5. Both the Hybrid and EcoBoost use direct injection. Some cars, like the 5.0 Mustang, use both direct and port injection. So they don't have a carbon buildup issue.
6. Carbon buildup on our Mavericks shouldn't be an issue until 70,000 miles, and may never be an issue.
7. From what I've read, fuel octane rating doesn't make much difference on carbon buildup on a direct injected engine. The Maverick manual, on page 172, says that octane rating does make a difference in some situations, like when you are towing. The manual recommends 91 octane to get the best performance out of your Maverick. But it also says that you can use 87 octane. You get to choose. Hey, it's America.
The Hybrid 2.5 is port injected, not direct injection.
CoryDallas8123
Cory
Dallas, TX
Audi A4, Chevy Chevelle SS, 2022 Maverick XLT
Hi all,
Thanks
If you’ve got the Hybrid what’s an extra $4-$5/fill up. With Hybrid fill ups should be few and far between, most likely.
Mainer500
Lou
Maine
Excellent info, thank you:)
TruckVille
Washington, DC
Yes, thank you. I just found that. Sorry for the incorrect info.
Down
Jason
Scottsdale, AZ
22 Maverick/02 Z06 Vette
I have an older 2.0l Ecoboost in my Escape and while I've never thrown it on a dyno to confirm (because why) but it certainly seems to run better and give slightly better gas mileage when running 91 instead of 87. Of course, I basically live on the surface of the sun in AZ, so heat is a pretty common occurrence.
Jonny44
Jon
Minnesota
2025 Mav hybrid AWD XLT, 2016 Ford Escape Titanium
Let's do some math here!
12,000 miles/yr @24mpg = 500 gallons of fuel
Cost of regular at $2.50 x 500 =$1,250
Cost of premium at $2.80 x500 = $1,400
An annual added cost of $150, or $12.50/month. But...a $45 or $60 sams/costco membership at least here in MN gets me premium for +/- $0.05 more, making the only difference the cost of the membership, less than $5/month.
And Costco uses "top tier" gas, which is a requirement for GDI engines like the EB.
Jonny44
Jon
Minnesota
When you start noticing oil consumption, you'll know that the valves and rings have carboned up on the GDI (gas direct injection) engines. Usually by then it's too late to just do an intake cleaning to stop it. It's an industry-wide issue that is only solved by installing new pistons and rings or a new short block. I would suggest on the EB engines to use something like CRC intake cleaner at every oil change. I've seen enough cars come in with issues after just 10,000 miles needing major engine work. Once you're out of warranty it will become a major expense.
TruckVille
Washington, DC
Yikes, thanks for the advice!
Is CRC the best product for that?
Should the average EcoBoost driver get it cleaned professionally? How often?
STARCOMMTREY1
Trey
Boligee, AL
Hi all,
Thanks
I never ran premium in our escape. No issues
Jonny44
Jon
Minnesota
It's pretty simple to do, but you'll need 2 people. One to spray the cleaner and one to rev (slightly) the engine. Best to do right before the oil change. There are many youtube videos showing the procedure. It looks like it will only apply to the EB engines as the 2.5 is listed on the Ford site as a port injected engine.
Jonny44
Jon
Minnesota
And the CRC product seems to get the best results.
r100gs91
Dan
The center of the USA
Don't know about you all but why Ford didn't add Port Injection to the 2.0 EB, during the design update a few years ago, is beyond me to understand.
