clavicus
I did this no difference in the camera at all that was disappointing
Has anyone else done this and seen a difference in the reverse camera at night? Since that is kind of the point of this mod, right?
Also here's screenshots that may help for comparing how much more lit the surrounding garage area gets:
Ford Maverick DIY - Maverick LED tail lights upgrade. Before and After Video 1638564083485
Ford Maverick DIY - Maverick LED tail lights upgrade. Before and After Video 1638564108119
kmish203
Jeep Renegade
Is the install the same on the Lariat trim? I know those taillights are slightly different.
Platinum2
MI
Ford
I really need to see the lights acting as turn signals to come to any conclusion. The brightness seems about the same, but my peeve with incandescents is that they don’t turn on and off quick enough for my liking when acting as turn signals. IMO all vehicles should have MANDATED amber signals or else the manufacturer gets hit with a $1B fine for each vehicle produced without amber signals. Or at least implement sequential turn signals, or use a separate bulb from the brakes.
We don't need any more mandates. Jesus Christ..... 🙄
jbpoole
Southeast
Ford F-150
Stay tuned for Diode Dynamics LED replacements for the Maverick.
They offer a wide selection of products to fit specific vehicles such as the Ford Ranger. I hope to replace every non-LED light and add yellow fog lights as well.
The Weatherman
Dean
KY
mav_can
BMW X3, 2018 Mustang EB Premium
It’s the most important mandate of all, only behind having to return your cart at the grocery store.
Decayed
yes
a car
I liked the part about the $1B fine per vehicle. That's certainly proportional. :rolleyes:
LadyMav
SJ
Thank you again for the video, did mine yesterday, next is the third brake light…need to find the link to that video again.
ugot2know
Yukon
Thank You for all the info, changed cargo and reverse to LED's
All went perfectly with your great info :)
mdl20813
Idaho
Cactus Gray Maverick XLT
Anyone else have a hell of a time getting their tail light assembly free while doing this? I removed the bolts but feel like I am going to snap the tail light trying to pull it away/out from the fender.
Hammer
Easton PA
2009 VW GTI
I had the same concern when I reached that same point of the taillight removal. There are two attach points which are narrow prongs on the back side of the taillight assembly ( the side toward the front of the vehicle if you are facing the tailgate ). You just have to give a firm tug and each one will release. They go back on much easier post bulb replacement, so just get past this step and you will be good.
Fleshman03
Georgia
2022 Maverick XLT
Any CANBUS-friendly LED that has a built in resistor - rather than a spliced in one - will overheat in about 7 minutes. I get this directly from the manufacturer of the CANBUS LEDs I've used in turn signals in many cars for many years.
Reverse bulbs don't need resistors because they're not going to hyper flash or cause error codes. My talk of the 7 minute thing was in regard to trying to find an LED that would work as both a tail/brake and a turn signal - as the Maverick uses the same bulb for all three, which is a complication. You could wire in a resistor, I suppose, but I'm not willing to splice wiring on a new car. But you're going to have to have a bulb that will both not hyper flash and not overheat. Maybe that exists and I don't know about it since I've not had a car use the same bulb for tail/brake/turn before.
I’m curious what you think of these:https://www.mavericktruckclub.com/forum/threads/installed-lasfit-4257-canbus-switchbacks.6961/
I ordered them and will install the pair this week.
