- First Name
- Jose
- May 26, 2024
- California
- 2024 Maverick XLT
- Engine
- 2.0L EcoBoost
Hey all! Below is my video on how to swap your axles if you're looking into doing it yourself. I voided my warranty because I lowered my XLT. So, I went through purchasing and replacing my own. I also upgraded to the Tremor CV axles while I was at it! (Ecoboost only, Hybrids, this would be just a replacement video, not a Tremor upgrade for you) Hope it helps!
Torque Values verified from Ford manual found here:
https://cardiagn.com/2021-2022-ford-maverick-p758-workshop-manual-incl-owners-manual/
Axle Nut: Step 1- 76 lb.ft TQ
Step 2- 45 Degrees
Shock Bolts: Step 1- 103 lb.ft TQ
Step 2- 120 Degrees
Sway Bar End Link Bolt: 81 lb.ft TQ
Brake Caliper Bolts: 81 lb.ft TQ
Part Numbers:
Driver-side CV Axle: PZ6Z-3B437-A
Passenger-side CV Axle: PZ6Z-3B436-A
Axle Nut: CCPZ-3B477-G
Step 2- 45 Degrees
Step 2- 120 Degrees
Part Numbers:
