mepot101
Orlando, Fl
2024 Ford Maverick
My solution for the flap gap on the left rear mudflap. I bought a 12x12 piece of kydex on Amazon, .080 thick. Link: https://www.amazon.com/Plastics-200...1&sprefix=12x12+piece+of+kydex,aps,129&sr=8-3
Had to cut about 1 inch off the side . Removed one upper plastic clip, and slid the piece of kydex up so it looks like the mirror image of the right side area behind the right flap.
Used a stainless 1/4 inch bolt and washers and a self locking nut to hold the top, and drilled 2 holes in the bottom and held with the extra clips from the mabett flap install.
I hope these pics show up, my computer skills are lacking. I got the install done quicker than trying to post this thread.:sadface:
Ford Maverick My mudflap gap fix using kydex thermoplastic sheet IMG_20240629_095646
801Maverick801
Utah
Subaru Forester
Why would Ford put an arch in the wheel well like that? I'm having a hard time understanding why they would do that.
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
I'd like to introduce you to Ford's accounting department, they have the answer for you.
MichaelG
Michael
SE Michigan
2002 Ranger
I can only think the flap is open is to prevent exhaust heat build-up.
Waterick
Laurens county SC
Any guesses as to whether Ford will address this area on the 2025 refresh? I like your solution by the way, very similar to what I did.
mepot101
mepot101
Orlando, Fl
2024 Ford Maverick
The right side has the storage cubby filling that area. The left side cubby would probably cover that area, I'm not sure. The xlt has the light and plug in on the cover , so no box. Seems like the aftermarket would have addressed this area, but my and others fix seem to be doing ok.
I don't think there is enough heat there to cause an issue, the kydex is cheap so if it de-forms, I have more. I got 4 12x12 pieces for $24.00 on amazon, from a company called 'plastic 2000'.
mepot101
mepot101
Orlando, Fl
2024 Ford Maverick
Thanks for the link, I can't figure out how to add it.:clap:
Fcnrwy
Jerry
Wisconsin
Maverick XL Area 51
The "Cubby" is not large enough to cover the void.
I did a large cover (somewhat like, those posted on other threads). Over the 4th, i plan on removing it to see any result. This OP's idea will be considered.. ;)
Jerry
Jeff W8
Western Washington
2023 Ford Maverick Lariat Hybrid
My solution for the flap gap on the left rear mudflap. I bought a 12x12 piece of kydex on Amazon, .080 thick. Link: https://www.amazon.com/Plastics-2000-KYDEX-Sheet-0-080/dp/B077S64M76/ref=sr_1_3?crid=380J4RA9SAKZZ&dib=eyJ2IjoiMSJ9.HyHC5vA9nuVrHTkgUQChz153XKZv9BcRbWIk7Mho9c4NNCNenJvqrC9e56kT86cIG3U_uQNg2V5cJlg3llkHT_W2EFF2X-Os1ToUvBPpDesZKbRvIvDGvjcnnX-gLOf2ySbKpPxOqg68XHnuzu7xOoPjAWXJLdKAQNtOukc_sed87Aw5Wt7WIq-ELWNab0r9m5KaZiFodpiv_FlGelkHJtXFkr3uyCb_m_frJ09njY4.Qi2DqYiyheTUjKDIG-wQlMvCbjnc8mfOk_aoCsxM1UY&dib_tag=se&keywords=12x12+piece+of+Kydex&qid=1719768191&sprefix=12x12+piece+of+kydex,aps,129&sr=8-3
Thank you!! I was being annoyed by that gap that just hits my eyes every time I look in that direction.
For anyone that is super super cheap like me, I found a normal ABS 12x12 sheet for $8 on Amazon:
https://a.co/d/0bp7kQ5T
It didn’t seem like the need was there for reforming the plastic with a heat gun, so normal ABS should work, correct?
mepot101
mepot101
Orlando, Fl
2024 Ford Maverick
Oh yea, plastic should work also.
I just figured I would find a use for some more kydex, don't know what , but something will crop up.
Toddman45
St. Louis, MO
Thanks mepot101, added to my list when I install my mabbet mud flaps.
Carlitos_92
mepot101
mepot101
Orlando, Fl
2024 Ford Maverick
Its easier for me to fix the flap gap, than it is to figure out how to do some computer stuff:blush:
