How I added to my Mabett Mudflap
Tbone289
MO
So these Maxzina mudflaps cover up that hole like the RokBlokz ones do for the Maverick? Are you using these Maxzina ones? Just got my 25 XLT on Thursday and looking into Mudflaps and came across this thread.
Yes, the Maxzina flaps cover the left rear hole completely. I have a set that I used for a while, but now I have custom-cut RallyArmor flaps.
ListedGuru
MI
Mercury
Thanks for the info on the Maxzina flaps. Do they touch the paint where it could cause it to rub off? Also is installation of them easy?
ListedGuru
MI
Mercury
I see your in Michigan, so I would be concerned about keeping the winter road mix out of there altogether. The cubby will prevent much of the crud from getting to the very rear, but I would think much of the stuff will still get thrown through the hole and be trapped there. I did grow up in Northern New England so I do know what you're up against. I'm not sure which trim level Maverick you've got, but it is easy to add an additional bed cubby on the left side of the XL and non-Lux package XLT. The part cost I think is about $50 from Ford. If you have a Lariat or an XLT with the Lux pack, then that cubby access panel already has the bed LED lamp and inventer outlet mounted in it and you would have to relocate them. I personally would not do the cubby as a block for this area, you can flush it out better without it. I would block the gap in the wheel well first, then add the under body cover either from Mabett or there are many ideas on this forum. I added the Mabett cover (about $90 I think). Now that I've installed it, I don't think I really needed it for my use case here in the South. I got it mostly because I made holiday trips to see family up North in years past and was able to get it at introductory pricing.
Hope this all helps, depending on your winter exposure, I would at the very least block that gap in the wheel well. This will keep most of the stuff from getting kicked up into that side panel. To help prevent more and airborne spray I would add an underbody cover. You may still want to flush it out until your comfortable with it staying clean. This can be done by removing that panel holding the light and outlet. Some people said they removed the tail light to flush it. Many have had problems getting the tail light to stay in after removal. Then there are others who use only a fluid film to prevent rust. (So much useful info on here!). Good luck trying to decide!
Thank you for the very detailed reply. I have an XLT w/Lux so I guess adding a cubby would probably be more hassle than it's worth unfortunately. I think blocking the gap in the wheel well is probably my best first step. It sounds to me that installing the Maxzina mudflaps would accomplish the issue of blocking that gap in the wheel well. I've had a few other replies here on the forum regarding the Maxzina flaps and they sound like what I'm looking for without breaking the bank.
I'm going to have to think some more about adding an underbody cover. I agree I probably should add something in that area but I think with the Mabett underbody cover you have to remove some existing bolts from the frame to mount it in which I'm not so sure I want to do. But like you mentioned there are many other options presented on this and other forums for covering that underbody area. Also thanks for the tip on flushing out the gap in the wheel well as this is probably a good idea to do until I come up with a more permanent solution.
Thanks again for taking the time to answer all my questions.
HenryFord
MO
This thread has been very helpful for sure. Pics of the Maxina on Amazon do look like they will cover that gap. I was planning to add the cubby as well so it looks like it should work out nicely.
ListedGuru
MI
Mercury
I thought about adding the cubby as well but I have an XLT w/Lux so I guess it has some LED's etc in that spot already that would have to be moved to probably more than I would want to mess with. I'm leaning towards getting these Maxzina flaps as they are way cheaper than the Rokblokz.
Jah.
Jah.
Central Florida
So I just picked up my XLT on Thursday and have been looking into Mudflaps. So just to clarify are you saying I can install the pickup bed cubby on the drivers side and it will cover up that gaping hole everyone is talking about? And if so would I still need to mudflaps?
Yea . I also have mudflaps with extension ( left side only) that were put on prior to cubby . my extension is made out of old flat mudflaps that were cut to fit and away from exhaust pipes . So I have double protection for that area . bought my mudflaps on Amazon for about $40 .
Ford Maverick How I added to my Mabett Mudflap 20250526_102803
ListedGuru
MI
Mercury
Thanks for the pic. My XLT has Lux Pkg so I guess there is an LED light and inverter in there where the driver side cubby would go so not sure if I want to mess around trying to relocate those or not.
ListedGuru
MI
Mercury
Does anyone know what the tool is called to remove the screws or maybe rivets to install the Maxzina mud flaps. I know someone mentioned a tool of some sort to remove some existing hardware that won't ruin the existing hardware. Does anyone know what this tool is and have a link? I can't find the post I read yesterday that mentioned it. I don't think the tool is required to install the Maxzina mud flaps but I'm curious what it is.
Jah.
Jah.
Central Florida
I used a small flat screw driver ( or something similar) to remove grommets . if you look closely at center of grommet there is usally a small slot that you push under to pop center piece up on that will release the grommet so it can be pulled out . grommet shown not ford but all are similar . 7 mm socket / wrench for two bolts .
Ford Maverick How I added to my Mabett Mudflap 20250526_160236
Ford Maverick How I added to my Mabett Mudflap 20250526_160410
2024_xl_hybrid b&w
Austin
NC
2024 Maverick XL hybrid
The mabett mud flaps come with this plastic pry bar which is very useful. I also used a flat head screwdriver to pop the pin first like @Jah. described. Then the pry bar to get it completely out. You can turn the pins so that the slot to put your screwdriver is at a better angle to pry. The tool is generally called an auto pin fastener removal tool on Amazon. If you were closer I'd give you mine. This is a set that has one on Amazon....
https://a.co/d/aQXVenk
Ford Maverick How I added to my Mabett Mudflap 20250526_163442
Ford Maverick How I added to my Mabett Mudflap 20250526_163433
ListedGuru
MI
Mercury
Thanks for the info. I'm actually looking into buying the Maxzina flaps but I'll have to see if they come with that tool at all - and any replacement hardware for that matter. I'll also check on Amazon to see how much those tools run. Might be handy to have on hand anyway.
2024_xl_hybrid b&w
Austin
NC
No problem. I edited that post with a link to a set I found on Amazon
2024_xl_hybrid b&w
Austin
NC
Yes seeing that now and thanks for the link. Seems like their probably worth $5:)
Agreed. You're most welcome and be sure to post pictures after your install. Enjoy the rest of your memorial day!
