Hybrid Oil change Overfilled @ filter
jgz1994
Angel
Charleston, SC
2024 Maverick XL
Hey y’all, I f***ed up
Doing my oil change on my hybrid. Pre-filled new filter to about 80% capacity (just under where the threads start) and forgot to account for this when adding oil up top. Added about 5.6 qts of new oil (by eyeing the markings on side of oil containers) and realized too late I hadn’t subtracted the amount of oil in filter. Haven’t started the truck and still on ramps, but here’s what the dip stick is showing. Wondering if I should be ok, or I should remove some. If so, how. Loosen filter to let some drain?
Ford Maverick Hybrid Oil change Overfilled @ filter IMG_2118
riparian
Virginia
2024 Maverick XLT hybrid
If it were me, I'd partially back out the drain plug to drain off the excess(I know, it will make a mess), wait a few minutes and recheck the level. I also check again after backing off the ramps. I'm a better safe than sorry guy.
Carlitos_92
I would not worry about the amount of oil in a filter. Spread out in an oil pan, you are not going to notice the rise that would create.
That said, I can't tell from your pic how far over or under you are. It took me forever to get a valid reading on my Ecoboost. I'd triple-check that level, and if it really does seem overfilled, do as the previous poster said, and let a little out via the drain plug.
Why do folks prefill the oil filter when it's so small🤏 ?
Really there is no practical advantage on a gas engine with such a small oil filter.
I'm guessing it's a feel-good kind of thing.
In regards to the OP's post #1
You probably just voided your warranty.😲 I'll take it off your hands for $7,000.
TRUCKHEF
SOCAL
22' Ford Maverick XLT
It'll be fine, just drive it. There's a tolerance in there, difference between low dot and high dot is 1 qt I believe. As long as its not over the top dot you should be fine.
OR3X
SC
2025 Maverick XL
I mean, being a little over full is better than being under full but neither should cause any catastrophic damage to the engine as long as it's showing on the dipstick I would just start it and let it idle for a couple seconds then shut off and recheck level after a minute or two. This usually causes the level on the dipstick to drop slightly as the new oil gets circulated by the oil pump. so if you're slightly over it would probably drop it down to the correct level without having to try to drain some out which always causes a mess in my experience. Good luck!
jgz1994
Angel
Charleston, SC
2024 Maverick XL
Thanks y’all for the replies. Ended up draining some from the bolt. I expected an oily mess but on the contrary, hardly any oil seeped past the threads as I loosened until I unthreaded the entire plug and just held it in place. Wasn’t gushing out like I thought. Probably because I hadn’t started the engine yet and pressure hadn’t built up.
Mean Green BP
Bruce
Covington, LA
2025 Lariat Eruption Green, 4K Tow, OEM Bed Extender & Light kit.
Perhaps from the days of bigger engines and bigger filters.
Though it is interesting the difference between factory filter and stated filter to use.
Does the EB do the same thing?
We're talking a miniscule oil filter especially on the hybrid 2.5 l
Ford Maverick Hybrid Oil change Overfilled @ filter 20250501_114709
Meeka
Jay
Castlegar B.C. Canada
2024 XLT 2.0 turbo
I’ve been doing oil changes on vehicles since ‘75’, that’s 1975 for you pups. Always been told to add some oil to filter and gasket, not much oil, just enough for initial start up. I would LOVE for someone here to tell me that now new engines would NOT benefit from this procedure. Still willing to accept new ideas and proof. 😉
