- First Name
- Mike
- May 3, 2024
- KC Metro area
- 2005 Toyota RAV4, 2024 XLT Hybrid
- Engine
- 2.5L Hybrid
Dip was Saturday night into Sunday morning.
OTA enabled and set for 1 am. Did not check for updates but am familiar with the process as I also own a Bronco Sport.
Cell signal can be spotty but 60% of the time, works every time. Have also setup to use the house wifi which is a stronger signal
60%...So it appears yours is keeping a high level - probably doing what the others do. 92% SOC.
Was that 2nd dip on the 28th during some drive time?
Now that first dip, for extended time starting the 20th.
Had you just finished a drive?
That whole extended decline - that appears to be classic parasitic draw down.
Not huge rate or you'd have gone lower with dead battery the next morning.
Reached or almost 12.1 V perhaps - so ya no battery save or deep sleep mode yet.
Appears you started right in time to prevent that - and it reset whatever was the issue.
Intermittent then since not the next night.
And it recovered - charged up just fine next day, if not better actually.
You might want to start your own thread on this - point us to it.
Since this thread is on normally non-issue system just plain undercharging.
Obviously doesn't help a parasitic draw.
