JetFixxxer
Jason
Massachusetts
2023 Lariat x2, Lux, Co-pilot 360 Assist
This should enable full featured climate tab on touchscreen.
I did not create this procedure, I am only documenting other's work.
As always, you should back up module and only try this at your own risk.
Apparently this only works to program while vehicle is running. Most modifications in Forscan use vehicle in acc mode, this one requires running.
In APIM Module
Enable:
Climate Overlay - Dual
Climate Overlay - Max AC
Climate Overlay - Max Defrost
Climate Overlay - Mode
Climate Overlay - Power
Climate Overlay - Recirculation
Climate Auto Seats
Heated Steering Wheel Icon
Seat Button Icon - change to 'Heated Seats'
Write and restart.
I have all those enabled, vehicle running, and I do not get an extra tab. Of all the FORScan both on my MAV and F150. This is the only thing that's not working.
BlackMav23
MI
2025 Lariat (Shadow Black, 4k Tow, Sunroof)
Has anyone increased the temperature of the steering wheel and/or seats?
I'd like to increase the wheel temperature as mine seems to turn off when it reaches x point (too frequent for my hands) but wondering if there's been any issues in doing so.
BlackMav23
MI
All Windows Up/Down with Press and Hold Fob Button (Lariat only)
Enable:
BCM (BdyCM)
Global Close Initial
Global Close Vehicle
Global Open Initial
Global Open Vehicle
Global Window Close w Remote
Global Window Open w Remote
DDM
Global Window Close
PDM
Global Window Close
https://www.mavericktruckclub.com/f...nfirmed-working-lariat-only.11092/post-758399
Does anyone know if perhaps this would work for the sunroof or maybe the drivers door on an XLT? I'd like to be able to let the hot air out before getting in the vehicle like I could with my VWs.
Honestly it's my biggest gripe with the XLT is the silly window controls. That and the speaker/head unit.
BlackMav23
MI
Disable Auto Stop/Start
1. Open PSCM (easy mode)
2. Disable Stop/Start
https://www.mavericktruckclub.com/f...-you-can-do-using-easy-mode.44179/post-811352
While we're at it... I'm confused. Does this disable Auto Start/Stop or does it rather disable Auto... Auto Start Stop?
I guess what I'm saying is that I don't want to get rid of the feature, I just would prefer it off by default when starting the vehicle. I don't think mine remembers after killing the ignition but I could be wrong.
Now the auto hold setting for the brake, I love that. Always irritates me on other vehicles that the vehicle will auto stop at lights but the slightest easing off the brakes or bump on the wheel and the engine would start back up and will idle forward if you take foot off. I'd throw on the parking brake on my Tiguan and take my foot off the brake and it would start right up again whether I was ready or not. So silly.
Toinky
Toyota Tacoma
I believe it just turns off the stop/start feature by default and you could press the button to get it back on, but I'm not sure. Someone else will have to check that because I don't disable it. (I like it--mostly.)
I agree that auto brake hold is great.
Aherpa
Iowa
Edge, Maverick Lariat Hybrid
I can say that on my 2019 Edge, disabling auto stop/start in the BCM disabled it totally. When you hit the button to activate it, the auto/stop/start icon on the dash shows up but it's grayed out with a line through it. Otherwise no ill effects.
BlackMav23
MI
I'll have to disable it manually and see if it remembers my setting after the ignition is shut off.
Apparently it works and is standard on vehicles for a reason, but in most cases (and I'm no mechanic) I'd imagine this causes premature wear on the engine if you are frequently stopped at short lights or 4 way stops.
EONR24
United States
2024 Ford Maverick XL
It disables it completely. I have tested it.
EONR24
United States
The lariat driver window switch uses a completely different connection than the the Xl and XLT. I tried to swap in a window switch from a lariat and it will not work without also adding a passenger and driver door module. So the mod is not worth it in my opinion because it would be a ton of work to try to make it happen. The funny thing is I enabled global windows open and close on my base model 2015 Focus ST and uses pretty much the same exact window switch as the Lariat maverick lol
Bwicka
Lakeside,ca.
Anyone found an easy mode for the seat belt warnings and ok screen?
Use search in upper right corner - seatbelt disable forscan , there is a few threads on it . One with easy mode , confirmed working.
allc0re
Ryan
2024 Hybrid Maverick XLT
Did that b4 i posted actually, didn't find
Why are you afraid to use the non-Easy-Mode method? There are at last two threads showing how to do it that way. It's not difficult and it works.
LPAHL
Alberta Canada
2025 Maverick XL shadow black
There is lots of useful information on MTC about using Forscan to make interesting and useful changes to the computer modules in our trucks. This post is not about using Forscan software or programming devices--you can find that information as a sticky in the Forscan forum.
This post is for those who don't speak hexadecimal* or are otherwise hesitant to change as-built codes (or for anyone who wants to make a quick change). I have compiled several changes you can make using "easy" (not as-built) mode. Instead of selecting a module through an as-built entry, look below it and there will be a module with the same name, but not as-built (not in all cases). Connect to that module. It's the same module, just named and accessed differently. The difference is that entries are in plain English [mostly]. Be sure to write the changes. Before doing any of these changes back up your as-built modules. Use at your own risk, of course, but these changes have all done well for me. I've included links in MTC for where more information can be found on these Forscan edits.
[*I know changing as-built modules does not require actually understanding hexadecimal--it's a figure of speech.]
Enable Traffic Sign Recognition (TSR)
IPMA:
Traffic Sign Recognition (TSR) - Speed Limit Information Function (SLIF)
Traffic Sign Recognition Mode - Camera data only
IPC:
Traffic Sign Recognition (TSR) - Disabled - Counterintuitive but important
Speed Limit Information Function (SLIF) - Enabled [if disabled you get European sign symbols]
https://www.mavericktruckclub.com/f...orscan-mod-confirmed-working.9399/post-748132
Adding Drive Modes
1. Enter ABS module and search for SDM
2. For SDM - ABS disable it
3. Depending which package you have installed enable the following if any say disabled
SDM - Mode 11 (Sport)
SDM - Mode 4 (Sand)
SDM - Mode 5 (Mud)
SDM - Mode 9 (Eco)
4. Check the DTC codes to see if you threw one
https://www.mavericktruckclub.com/f...-and-snow-confirmed-working.10229/post-211182
Stop being locked out of functions due to being in motion
ACM
Driver Restriction Configuration - Disabled
https://www.mavericktruckclub.com/forum/threads/for-your-safety-blah-blah-blah.35866/post-690772
"Disable" Key Fob Panic Button
No 2 press option on Mavs (that I can find; available on other Ford vehicles)
BCM (BdyCM)
Panic Alarm Mode - Lights Only
https://www.mavericktruckclub.com/forum/threads/disable-panic-alarm.21229/
Disable double honk when exiting running vehicle
BCM (BdyCM)
Double Honk on Leaving Cabine [sic] - Disabled
https://www.mavericktruckclub.com/forum/threads/disabling-double-horn-chirp.9208/post-555900
Enable ECO Coach (indicators about improving fuel economy)
IPC
Enable:
ECO Mode
Eco Coach Feature
Eco Coach with Efficient Drive Mode
https://www.mavericktruckclub.com/forum/threads/forscan-mod-–-enable-eco-coach-mode.25533/post-777948
Enable:
BCM (BdyCM)
Global Open Initial
Global Open Vehicle
DDM
Global Window Close
PDM
Global Window Close
I created this thread to help others not have to cull through all the various threads and posts with lots of replies and superfluous information. Please feel free to add to this list of Forscan edits, but it would be good to stay true to the attempt to include only instructions for easy mode.
===Addendum (submitted by others and not tested by me)===
Adjust Heated Steering Wheel Temperature (if equipped)
SCCM
Change value to desired degree in Celsius
https://www.mavericktruckclub.com/f...-you-can-do-using-easy-mode.44179/post-780569
Adjust Heated Seats L/R Temperature (if equipped)
HVAC
[I haven't actually done this one; I have no need. However, it seems obvious that it would work.]
Enable Radio ST Animation
1. ACM
2. Under “Animation Type” change Standard Ford to ST.
https://www.mavericktruckclub.com/f...-you-can-do-using-easy-mode.44179/post-785360
Average Speed Display
IPC
Enable Average Speed Display
https://www.mavericktruckclub.com/f...-you-can-do-using-easy-mode.44179/post-808769
IPMA:
IPC:
Adding Drive Modes
SDM - Mode 4 (Sand)
SDM - Mode 5 (Mud)
SDM - Mode 9 (Eco)
ACM
BCM (BdyCM)
BCM (BdyCM)
IPC
Enable:
ECO Mode
Eco Coach Feature
Enable:
BCM (BdyCM)
Global Open Initial
Global Open Vehicle
DDM
Global Window Close
PDM
Global Window Close
SCCM
HVAC
1. ACM
IPC
Has Anyone Done the EZ drive mode enable on A 2025 Maverick XL non FX4? Its not called mud and ruts anymore i think its just called offroad now
