Jpalmer1
Dallas, TX
2025 Lariat Hybrid AWD
In another thread 2025 owners are having success enabling the AWD Screen in “My View” without enabling additional Drive Modes. However, I tried it on my 2025 Lariat Hybrid AWD but couldn’t get it to work. I tried what
Is working fo others . . IPC 720-07-02 x7xx-xx on but it did NOT work. My original was IPC 720-07-02 0500 083D . . when I change the 5 to a 7, it automatically changes the D to and F, resulting in IPC 720-07-02 0700 083F. I tried to change the D back to an F, but it persists and won't accept the D . . ? When leaving the F and testing, I can't determine anything happened or changed . . My View and everything else seems same as before . . ?
papawmark
Colorado
2023 Ford Maverick Lariat FX4/2023 Ford Bronco Sport Big Bend
Lobo mode for me is a Cobb Accessport.😉
Jpalmer1
Dallas, TX
CORRECTION . . it actually worked as advertised. The other owners pointed out I simply had to “select it” in the My View configuration.
Vtec87pr1
Antonio
Virginia
youtube.com
2022 XL Ford Maverick
I tried this today. I did show Lobo mode. But I ended up DCT codes in ABS & IPC. And Check Service Engine light.
At first, I didn't do the 760-04-01 xxxx-xxxx-x0xxx change. At that point I didn't have Lobo mode as expected.
Then I did that change.
That is when Lobo showed up. When going to that mode that is when I got the DTCs.
Since sometimes DTCs show up when doing the writes (as things switch around on the Mav's computer), so I cleared them. I confirmed I did not have DTCs, then switched to Lobo mode. Then I would get a DTC.
I cleared the DTC again and let the truck sit for a while. Went back and proved no DTC. Went to Lobo mode and DRC came back. I decided I didn't want to run it, so I put things back.
What is odd, is I still got the IPC one. It said something about it didn't like the ABS data; sorry didn't grab a screen shot of that. Again, only when I switched drive modes. So maybe there is something else. I reloaded my original ABS and IPC values and still was getting the IPC DTC.
Here is the ABS DTC I was getting. I suspect this is because I don't have the proper rear dif.
Disable abs
Mabcim
Rochester, NY
TremoringDan
Dan
Morrisville, NY
2026 Maverick Tremor, 2026 Maverick Lobo
I know I'm late to the party here but which module is edited to add mode 9 - Lobo mode ?
Edit: It's in the ABS module and I tried all the other modes listed in Easy Mode - only Lobo would enable.
