Do you recommend adding weight in bed for winter driving
Rentech54
Marcel
Calgary Alberta Canada
2023 Maverick XLT AWD
I just picked up my 2023 AWD XLT. Waited 6 months for it.
Previous truck was a 2011 Ford Ranger which unfortunately I ran into a parking lot post during an icy road and totaled it.
In order for extra traction I had to add a couple of hundred pounds of sand for winter driving.
What are your experiences with the Maverick?
Thanks
fossil
ernie
ohio
your truck is pretty light in the rear, a couple hundred# would help the balance and certainly not hurt anything. you can always use the sand as a traction aide if you get stuck.
bgn
WA
Nope. It's front wheel biased and will engage the AWD when needed. It's very quick to engage when needed (within milliseconds when it's needed).
Saltwater Cowboys
Josh
ENC
09 Ram 1500, 23 CG XTL Lux, 24 SB Lariat BAP
RWD truck yes - I always kept a couple hundred pounds of sand or gravel in the bed of my Ram during the winter when I lived up north because I didn't often drive it with the 4WD engaged.
AWD Maverick - not necessary.
tom_tucker
mid atlantic (VA)
2023 Maverick XLT (FWD)
Benilla
Edmonton
Winter tires will suffice through a Canadian winter as long as you're driving for the conditions
commadorebob
I don't. But I live in Alabama. :)
Shouldn't be unnecessary, but won't hurt to be prepared.
Ford Maverick Maniac
Huntington Beach & Park City
2 XLTs: hybrid alto blue & turbo AWD carb gray.
Marcel,
Don't carry extra weight it will affect your mpg. My AWD is in Park City. What surprised me is even with the huge snow year last winter, I never had to put chains on once. And I never got stopped at chain control even though I just had the stock Conti street tires.
This video should help you. I made it up a fairly steep road to Olympic Park no problem. It was so slippery that a Ford Transit had to be towed.
DanielP
Daniel
Mechanicsville, VA
Ford Ranger XLT
Thanks
My recommendation - move to the Sunshine State - just poking fun.
LSchicago
Lloyd
IL
No. This was only a thing on RWD trucks. Zero need, and would actually make braking worse.
dalola
Retired
SE Ohio 🇺🇸
Speaking in very general terms, more weight is typically an advantage in navigating inclement weather.
However, many factors would apply to whether or not adding additional rear weight (to an AWD Maverick) would aid in any significant way, to your use case.
For the typical winter driver/conditions, it's probably not worth the effort. But, if you're into more extreme conditions/situations, you may gain capability.
Or, if it just helps you sleep better at night, go for it. 🤠
billbillw
Metro Atlanta
'23 Maverick Lariat FX4
The last time I needed weight in the back of my vehicle for winter was with a 1983 Mustang GT with fairly bald Michelin TRX tires.
Don't need it with the Maverick.
