Havick
Chad
Windsor, ON
2022 FX4 Maverick & 1988 Mustang GT
Looks great!! and a nice detailed write up too. I liked how you made it look factory by using the 4K tow package panel. Thanks for sharing.
Dad
Honestly, the cable is $40, the software is free, and borrow a laptop? Or maybe make a friend on here who can help? There is nothing to worry about with Forscan. You would have to accidentally click into the wrong thing, accidentally change a setting, ignore the warning message, and accidentally write the change. At any point if you decide something isn't right, you just stop and no harm done. But we are literally talking about a few drop-down menus. It's probably harder to get on here and write a message.
But, point taken. It doesn't have to be for everyone.
Honestly on the fence about using the F-150 switch and fooling with Forscan or going the route provided by the OP until reading your post on using Forscan. I can't tell you how much more confidence I've gotten by being a member of this club and tackling different modifications with the help of members such as yourself. While I commend the OP for the great job he did on his version of the install, it does seem like using the F-150 OEM switch and Forscan would make for a cleaner and quicker modification.
Dad
Great job with excellent attention to detail and craftsmanship. I'm guessing you have one switch for each fog light?
HSBII
HSBII
Sam
2017 Super Duty 2024 Maverick
Thanks
Much less complicated than going the F150 switch and Forscan route…
No the supplied DD electronic relay and wiring controls both lights and as noted in my write up it is for future lighting upgrades….
bobbyd454
bob
usa
2025 ford maverick
Finally had some time to install my @Diode Dynamics Fog Lights several weeks ago the install was easy and my install was slightly different and not exactly per the suggested instructions from DD..
I started my install by doing the Fog Light switch inside the cab, I didn’t want to mess with going the F150 switch route and the needed forscan thing for several reasons.. So before installing while I was considering who what and where as well as looking at what others had done I came up with an idea.
I got the idea while reading one of the threads posted about towing and the factory brake controller.. Since I own a hybrid and do not have the 4k tow package thought I’d look into tow package's lower panel as it it might offer a perfect location for a couple of toggle switch’s.. I started searching the web and bought a lower panel it comes without the controller but has the mounting bezel.. This looked like it was going to be rather simple, all I needed to do was make a small plate/panel to fit into the controllers location.. I already had some textured ABS plastic sheet it was 1/8’’ thick and should do the trick..
I measured the opening and then cut myself several piece's to have some backups just in case.. As I started to fit the small plastic panel to the bezel opening it was not sitting as flush as I would like so I decided to cut a shallow bevel on the back of it to make it fit more flush with the bezels mounting face.. Once fitment was to my liking I centered and spaced my 2 new switch’s location in the panel marked it and cut there openings out, when I was happy with the fit of the panel and the switch’s I then used some ABS glue since both were ABS plastic to bond them together..
Next was the fog's wiring harness while not totally following the DD provided instruction, I decided to locate the electronic relay in a location where it would be accessible if I ever needed (if this thing ever took a dump I did not want to have to pull the whole front end off just to replace it) the decided location was on the drivers side frame inside the engine compartment...
It fit nicely in that location and also allowed me to shorten up some portions of the supplied mile long control switch wiring harness so I drilled a hole and mounted it. For the ground I tagged a factory frame ground only a few inches away, as well as the relays + power tap.
For the fog lights toggle switch’s power I tied that into the drivers side headlight wiring instead of the passengers side, since I do not like or use T taps I soldered my splices to the factory wiring and coated them with liquid electrical tape once dry I then taped them up and installed some corrugated plastic wire loom…
I made my own wiring harness assembly to go into the cab I added a 6 pin molex plug and extra wiring for possible future lighting additions, I ran my wire bundle thru the large firewall plug on the drivers side, attached the wires to my switch's and spliced the needed wires into the trucks and DD wiring harness.. After the control wiring was roughly laid out and as I installed them I added some corrugated plastic wire loom to wiring harness's to keep things looking clean and close to factory... I decided to do a quick test with one of the lights just to make sure all was working as intended and it did....
Now that the wiring is all sorted out other than plugging the lights in and before I go and pull the complete front grill and bumper assembly off of the truck, I had already gave this some thought before I ever even ordered my lights. I thought why cant I just cut the openings for the fog lights from the front while the bumpers still on the truck.. I had looked at some of the install videos and didn't see any reason why it could not be done, as it would be a heck of a lot easier doing this work while the bumper is on the truck than on a makeshift work bench...
I decided I would just rough in an opening on the raised portion up of the bumpers lights locations.. I started with a hole saw and cut out the 4 corners of that raised portion I used 2 different sizes, then I just took my oscillating saw and cut between the holes both did a very clean job...
Once the openings were roughed in I then took the lights mounting trim ring put it thru the hole aligned it inside the opening and began to use it as a visual guide to do the finish trimming out of the remainder of the openings as needed.. Once I thought it was good I used the fog light assembly itself to finish trimming the opening up and make sure they were fitting flush on the bumper…
As you can see from the pic I ended up with about a 3/8” perimeter on the top the bottom and the outside edge and about 1/2” on the inside edge for the lights to sit flush.. On the drivers side I needed to take out the annoying backup alarm or as Ford calls it Pedestrian Safety System, it was easy to remove thru the new opening I needed to do this in order to allow clearance for the lights fitment...
Now with all the really hard and dirty work done it was time for the easy part remove the front grill and bumper assembly from the truck.. Disassembly was pretty straight forward as per the instructions although not in the instructions I removed the lower splash shield as it frees up a couple of attachment points on each side that it shares with the fender liners.. I also removed an additional fender liner clip per side which gave me more working room in the inner fender/bumper area.. The 3 per side 10mm bolts with my big hands were a little fun I used a 1/4'' socket and ratchet to loose and to reinstall them not a lot of working room in there so I put some grip tape on my socket which made it much easier to remove and install the bolts by hand… The rest of the removal was as per the book, I did it solo but a extra pair of hands would have been nice when I finally pulled it off...
I did not like DD suggested route for the passenger's side fog light wiring so I changed it and ran it below along a frame cross member under the radiator there is a small channel in it with some holes that were a perfect fit for it and some wire ties to hold it in place…
Now with the bumper and grille off and on a padded table it was easy to just install the lights, and now the grill and bumper was just about ready to reinstall on the truck...
I did some additional changes to the truck while the bumper was off I did not remount the backup alarm in the suggested location did some additional work to relocated it to the rear of the truck… I also relocated my horns to the passengers side I tucked them in behind the bumper…
Don't think I will be doing that.
Thex
Kansas
2022 Maverick Hybrid
Nice job with the switches! I added a lighted push button in the headlight panel.  I also left room to add a second switch.
Ford Maverick DIY Diode Dynamics Fog Lights Install (Pic Heavy) PXL_20240917_124624840
As a person who has used and has to continue to use FORSCAN to add cruise control to his 22-XL, I too was apprehensive to add the F150 switch. Every time there is a recall done, I have to renew my FORSCAN license just to re-enable cruise (three times this year!) For me, it is easy (now!) but I also didn't want to have to "enable" one other thing when an update is done.
Charles T.
Charles T.
Metro Atlanta
2017 Edge. 2025 Maverick Lariat
Yeah. Honestly sounds like more trouble than it’s worth.
—EDIT because I kind of think I am coming across as rude here and I really don’t mean it that way—
I think for me (and presumably people like OP who might be thinking like me), Forscan is added expense (I’d need to buy a Windows laptop, the connecting cable, and the software) and added risk (it might sound and seem easy, but you can mess stuff up with Forscan and it sounds like it can be a headache to undo, even if permanent damage is unlikely). I also personally wouldn’t find futzing around with Forscan fun at all, at least compared to getting out some wrenches and taking things apart.
So that’s a bunch of negatives right there, at least for me/someone thinking like me. And what do you get for it? A more OEM-seeming setup, for sure but…that just isn’t a valuable enough trade-off for me to make. If you enjoy the computer side of tinkering and already have the equipment then the cost and risk might be worth it for you but that’s not the case for everyone. Just trying to explain to give you an answer as to why not everyone would want to go the F-150 switch/Forscan route.
amen
PeachsBestFriend
Jay
Los Angeles, CA
2025 Ford Maverick XLT Hybrid AWD
I think this push button setup is exactly the way I want to go, though I’ll probably throw the second switch in at the same time just to make sure I space things out right for more lights later. That looks clean. Nice work!
Dad
Thanks
Aha! I must of missed that detail in your write-up. Thanks for the clarification and I think installing that second switch is a wise decision.
As I mentioned in a reply to another member on your thread, I too was a bit intimidated by the Forscan process and not keen on trying to acquire a Windows laptop and delving into unfamiliar tech territory. However, members here have proven to be so remarkably helpful and patient in guiding me and others with various modifications that I'm leaning towards giving it a try when I decide to get the DD fogs (a great value, by the way). I certainly appreciate your post giving folks who are better at mechanical modifications another alternative. You have definitely shown yourself to be a valued member.
Dad
Thanks for mentioning how the recalls affect the Forscan mod on cruise control. My Lariat has ACC, so I'd be more concerned how the recalls might effect the F-150 fog switch install. Have you had that experience yet?
Thex
Kansas
The recalls only have only affected certain modules. For cruise I had to FORSCAN 3 (or 4 modules) to add cruise. I had to reFORSCAN two of the modules for the first recall and then only the BCM for the last two/three. (I am loosing track :LOL: )
When you use a different switch (F150 headlight switch) or steering wheel switches (for cruise) you have to tell the TRUCK which switches are installed.
When a recall is performed on a module, it will overwrite ANY changes you have made to that module. Thus defaulting to the switches "as built."
HSBII
HSBII
Sam
Thanks….
I was not intimidated by programming with Forscan been there done that when Forscan was first being Beta tested back in 2014 on my F150 and on my 2017 F250… I no longer have a laptop and or a need for one.. I didn’t want the hassle of having to reprogram when ever Ford had an update and the update would rewrite the trucks as built programming and as we all know Ford has had many of them not only on these trucks but across the complete lineup. Also I dont want to have to hassle with the ford dealer if there is ever a warranty issue with the BCM…
A Dodge that drives Fords
Wisconsin
Ford Taurus Ford Ranger
I like it. Looks clean to me 👍
Dad
Thanks….
You're welcome. Ya, I have to agree with you on the warranty issue. One just never knows when you might get a cranky dealer who's looking for anything to void your warranty.
