Vtec87pr1
Antonio
Virginia
youtube.com
2022 XL Ford Maverick
Well first off it’s not just the reconfiguration of the factory programming with Forscan you also have to tap into the BCM.
From what I have read you will also have to redo the changes anytime Ford has an update to the trucks computer system…
As for your comment on it being probably more reliable, please explain to all of us how it could possibly be more reliable than a manual set of contacts triggered by a toggle switch..
In an addition how can you add or complete an additional set of contacts with the F150 switch, as I said I wanted 2 switch’s for my truck obviously one is for the Fogs and one will be for additional LED lighting..
If I could have found 2 push button style switches that would have fit into the small space of the electronic brake controllers bezel I would have used them as they would have more closely matched the factory headlight switch style..
In my opinion it looks pretty dam good and functional also I didnt have to cut up or drill any part of my dash, tap into the BCM, or change the as builds in addition if need be I can return it to stock which I dought I will ever need to do….
Lastly as another member pointed out I do not have a laptop and do not want to buy one as I do not have the need for one and would not want to borrow one either..
Had mine couple of years now no problems at all I was the original one that made the post way before diode dynamics made fog lights for put trucks. Just In case you where wondering about the reliability of the clean 2 wires to the bcm setup and no other wires going to battery or additional relays etc wires everywhere.
HSBII
HSBII
Sam
2017 Super Duty 2024 Maverick
Thanks
But I wasn't wondering and had no concerns about any reliability of the connections to the BCM. It was simply a route I decided not to take...
