jonshep
SW Oklahoma
Years ago I built one for the F150 I had. I had some scrap 2x6 so I cut a piece for the width of the bed that fit the indentions at about the same location as the OP's, to that I attached to lengths perpendicular that ran back to the tailgate. That provided three square places at the back of the bed to drop things into and kept them from sliding around. It was really useful when I had to refill my 5 gallon mower gas can. It was very simple, cost was near $0.
Robby2365
Robert
Not my original idea, saw a photo of it elsewhere and decided to build my own. Sharing my build instructions after someone else asked me for them. Lots of room for tweaking. Gotta love the FlexBed!
Materials:
  • Two 2x4" 6' or longer pieces of wood
  • 6-20+ 6" deck screws
Tools:
  • Screwdriver
  • Saw (hand, power)
  • Drill (Pilot holes makes things easier)
Assembly:
  1. Cut two 54 1/8" pieces from the lengths, optional cut corners from one side of a length. I have a lined bed, for bare metal bed you might want to go slightly longer. Test that the long boards fit in and out easily before proceeding, you may need to trim a little off. Better to start longer and shorten as needed.
  2. Cut one, or more, 4" pieces from the remaining wood. I used 5 total.
  3. Place all the pieces flat, small pieces between the lengths. Put one piece at each end, then space rest along length as you desire.
  4. Drill pilot holes into edges of lengths where you will be putting spacer blocks.
  5. Screw from edges into the spacer pieces. You can get away with one screw but I used two from each side.
Optional:
  • Cut corners off edges to allow divider to rest against bed, or leave corners to have divider float 1/2" above bed.
  • Stain, paint, weather treat wood, or use treated wood.
  • Affix eye bolts or hooks along length of bar to affix bags, straps or other items to.
  • Add cut material, rubber, etc. to ends so they don't scrape edges of bed.
  • @k2rizzle pointed out some nice hooks that work well with this. https://a.co/d/ehdnsBF
  • Screw in feet (or similar)
Emergency uses:
  • Fuel for fire.
  • Weapon.
  • Stakes for defense against vampires.
Robby2365
Robert
Materials:
Tools:
  • Screwdriver
  • Saw (hand, power)
Assembly:
Optional:
Emergency uses:
  • Fuel for fire.
  • Weapon.
Thanks for info great idea going to try. One question about emergency use. Will it really work as a stake against a vampire? I don't want to get caught in that situation and find out it doesn't. Take care
Realtruck
Diamond Sponsor
Realtruck
Ocala FL
Materials:
Tools:
  • Screwdriver
  • Saw (hand, power)
Assembly:
Optional:
Emergency uses:
  • Fuel for fire.
  • Weapon.
Gotta watch out for them vampires! 👀
This looks nice, and that's handy craftsmanship!
scottjl
scottjl
Midwest USA
'25 Lariat Eruption Green, 4k, BAP
You may have to perform some disassembly first. If you need instructions please DM me.
Thanks! Trust me, I am not a carpenter!
dochawk
doc
Las Vegas
So my OCD is wondering, why isn't the middle block centered?
It had a long, stressful, day.
Give it a beer, a dimly lit room with a recliner, and half an hour, and it will be centered again.
I installed a TMat system in the bed of my Mav
You say "TMat." I say "most lopsided game of Tic Tac Toe in history!"
i would never trust someone else to pick my produce 🤣
I'm more likely to trust some else to pick the produce than I am for it do rematerialize properly after going over wifi . . .
i love this pic!
Anyone else noticed that it lost a box?
Also, caption most excellent chinglish are needing!
Mbundi2023
Wyoming
2023 Maverick Hybrid
Not my original idea, saw a photo of it elsewhere and decided to build my own. Sharing my build instructions after someone else asked me for them. Lots of room for tweaking. Gotta love the FlexBed! Total time, about a hour for me with table saw and power tools.
Materials:
Tools:
  • Screwdriver (hand, power)
  • Saw (hand, power)
Assembly:
Optional:
  • Add cut material, rubber, etc. to ends so they don't scrape sides of bed.
  • Screw in feet (or similar) can go on bottom to lift from bed, or sides to adjust width to fit.
Emergency uses:
  • Fuel for fire. 🔥
  • Weapon. ⚔
  • Stakes for defense against vampires. 🧛‍♂️
I did something similar but hinged it in the middle so I can just remove a pin, fold it, and lay it in the back without taking up so much room. It also makes it possible to remove it without having to fold back my trifold cover.
go ahead and steal. i just ordered those hooks, will be attaching them this weekend! thanks for sharing!
In my small town HEB there are three to seven staff pulling groceries including produce at any time. There are seven parking spots reserved to park in while employees bring orders out to cars. When ordering online you have to schedule your pickup time. I never used the option but I expect that you are allowed to inspect the produce at pickup.
I saw a movie that had an alien vampire woman that most couldn't bear to drive a stake into.
scottjl
scottjl
Midwest USA
can you post a pic or instructions? i would have to pin mine off-center because of the block thereabouts. not sure how much more hate that would get me, but would off-set the license plate more! 🤣
Mbundi2023
Wyoming
[/QUOTE
There are the 2 hinges in the middle. I remove the 2 pins and then pull the divider forward to fold it and remove or lay it down. Certainly wouldn’t need to be that tall but I had the piece of plywood setting around.
Ford Maverick DIY Bed Divider IMG_4855
Mbundi2023
Wyoming
Where is the pin that you pull? With the hinges on the tailgate-side, what keeps it from folding in?
HRG
The pins are in the 2 hinges. Can’t fold forward or backward with the pins in. When I take the pins out the middle pulls towards the tailgate to fold it.
HRG
He's not going to tell you there are hinges on the other side also to keep it from folding the other way.
