wax87
Stuart
Dallas South
2004 Avalon
I've got no actual use for fog lights, but this kit looks extraordinarily attractive. If I find $300 under my pillow tomorrow morning this is how I'll spend it.
Do you have gold fillings in your teeth for the Tooth Fairy?
Mdavis
Michael
2024 Maverick XLT
Wow. Have been looking at these for about a month now. They look AWESOME. Thanks for sharing.
Huchipapa
Houston
'01 Trooper; '04 9-3; '13 Outback; '24 Mav Lariat
I wish our local distributor had installer recommendations. I watched the video 3 times…for those of us who are “all thumbs” it might be a ‘bridge too far’.
94tbird
94tbird
Ron
Treasure Island
2024 Ford Maverick Lariat
Use the video on conjunction with the step by step written directions and it makes it easier. All thumbs ppl can do this I ln a day no problem
Vettereddie
MD
2023 Maverick XLT
Pulled the trigger and ordered in white with the intent to use as driving lights in tandem with the low beams vs. fog only. If the activation switch is bypassed, does anyone know if they would be off during daytime driving or if pin 3 of the passenger headlight connector (blue wire with green stripe) is always active? Will try to get a meter on it at some point, assuming it's +12V/0V only and not a discrete digital signal.
Old Ford Guy
Rod
Northeast Ohio
2024 Maverick Hybrid Lariat ; 2016 Linc Navigator
IHateSpeedbumps
Nick
Central Texas
Following the "easy" way should be possible for most people. I am starting to look for someone who can work with me to install them using the F150 headlight switch and wire them that way so as not to damage any wires and not needing to mount a switch somewhere
Bobert47
Bobert
Kentucky, US
2023 Ford Maverick Lariat
This is what I also have planned! I just got my f150 hybrid headlight switch in and I'm waiting for the DD kit to ship. I do have one (maybe silly) question....where is the green wire (DU2Z-14474-DA) connecting other than the BCM?
710-oil-614
Cal
2025 Hybrid AWD Lariat
Jonathan
potential maverick buyer
Mine stay on with the high beams unless shut off. Mounted a switch to the right of the headlight selector. Don't want them on unless I need them. Having them on with the high beams in fog/snow/rain is counter productive as they ruin the distance sight anyway.
I got this same switch to swap out the one from DD, but am confused on which leads it goes on - i assume the ground chassis goes to common, and then the others are NO and + ?
