- First Name
- Jon
- Dec 13, 2023
- Alhambra, IL
- 2024 Mav Lariat Lux FX4, 4k tow
- Engine
- 2.0L EcoBoost
lol I knew it!I am, 225
ehh . . . I had a '74 super beetle in high school. As it warmed up, the cable for the heater started pulling down (cooler), and was as busy as the shifter!I learned on a VW bug. . . . Nowadays, one has navigation, music streams, climate control to worry about
Yes, I, too, go through much tissue crying when forced to drive an automatic . . .Not so with an automatic that shifts via wire. I'd rather use that space for the Kleenex box, thank you very much.
I had a girlfriend in high school whose father tried to teach her to drive a manual in his truck, a mid 70s I presume.Yep, some heavy clutches back in the day.
That doesn't sound fun! As Scooby-Doo would say "Rah-Ro".ehh . . . I had a '74 super beetle in high school. As it warmed up, the cable for the heater started pulling down (cooler), and was as busy as the shifter!
She simply wasn't heavy enough to operate it, and ended up in the air instead!
I found most of the old steering column stalks were awkward to shift. Many of them required high effort to get out of park but then you could easily overshoot into neutral instead of reverse or into 2nd instead of drive, etc. Probably just poor design that could be rectified in a modern version, though.A steering column stalk is absolutely the right place to put an automatic shifter. We only went to console automatic shifters because every guy driving a mommy automatic wanted to fantasize that he was driving a 1960s era muscle car.
Gotta throw my two cents inExactlyThe dial style gear selector allows easier access to the cup holders.
yeah, that.That doesn't sound fun! As Scooby-Doo would say "Rah-Ro".
The only one I ever had an issue with that on was a '71 Plymouth Fury III.Many of them required high effort to get out of park but then you could easily overshoot into neutral instead of reverse or into 2nd instead of drive, etc.
6'3 here. Have not even come close to that. That is an odd thing to happen.I just received a 2024 Hybrid XLT. Pretty disappointed so far, but it's a company car/truck.
Being that I am 6'2 and move my legs, in doing so, I have hit the rotary dial at least 4 times while in cruise control knocking it into neutral or reverse.
I have read that someone installed an F-150 shifter. Are there any updates, pics, videos on this?
And would it work on a 2024?
Pulling the hood release instead of the parking brake release. Been there done that, 72 Chrysler Newport.yeah, that.
After several minutes, it would reach some kind of equilibrium.
The bright side was that being air cooled, it simply ran the air through pipes in the muffler, meaning hot air after about a minute.
You had to pull it nearly to your chin, it felt like.
Now, couple that with the hood release being where the brake release belonged . . . after having to stop for gas in a bad part of town just a few miles from home, on a 400 mile drive, I ended up hitting the hood release. I drove on rather than getting out again.
Getting off the freeway, at the stop sign I didn't set the brake, not wanting to do it again, when I went to latch the hood.
About as I reached the front wheel, the car starts going backwards. I dashed around the door, hopped in . . . and missed the brake due to the collision.
It punched out the grill and collapsed the hood of the Honda behind me.
I figured that I hadn't pulled the shifter far enough back, and left it in reverse, but the adjuster was absolutely convinced that it had popped out of gear. She was just happy that noone was hurt, having just dealt with one of the fatalities from a gear-popping Audi.
And my car? Not even a scuff on the bumper pads!
I use cruise a LOT - even around town, if the situation is appropriate. For any given posted speed limit, I already know how fast I want to go. Cruise keeps me out of trouble.Ok - when using cruise control - does no one else move their legs around the minor space available?
Where does your go-pedal leg go when using cruise?
same thing as when the shift lever comes off in my hand!Wait till the dial comes off in your hand, Then what will you do ?
I've gotten used to it. If it's not better, it's not worse. Just something to deal with.So I have grown to like the dial shifter. Would like some sort of buttons on the dash. I get board and I had to teach myself it is not a fidget spinner at lights! Hence the desire for buttons! I have slammed this puppy into reverse and park at times. Albeit it while it was stopped.
