The64
Watertown, NY
nothing
I wonder if a mechanical device doesn't exist that could push the button the required number of times each time the car is started. I know they make devices like this for screens and repetitive tasks.
CubanRedneck
CubanRedneck
JC
Southwest Florida
...well in many ways that is what this is! I am not sending any signal to the ECU or anything of the sort. All this module does is automates the mechanical function of the switch.
My dad was a master electrician and did quite a bit of industrial control in his day. After pouring over his books for several days and diagnosing the task required, I came to the conclusion that using a couple of over-the-counter timers in series was the best solution.
CubanRedneck
CubanRedneck
JC
Southwest Florida
Is there any reason Ford couldn't adjust this with a software update that would keep the truck in eco mode by default?
I am sure there is a reason(s) and it more than likely has to do with that broad range of OEM suppliers and TRIMS. Know that it is not only Ford, other automakers have been doing the same for a while.
noticon75
Manhattan, KS
17 Ford F250, 15 VW Passat,
I know Ford has made vehicles that will hold the Eco mode. My daughters 16 Fusion Hybrid does this so why they won't/"can't" to the Maverick is beyond me!
CubanRedneck
CubanRedneck
JC
Southwest Florida
I posted this response earlier, but somehow, it was not published. All of the vehicles in the C2 platform suffer from the same deficiencies. Much has to do with the decentralization of the ECU into 14 separate modules. This is very good for the consumer because if a module goes bad is like $100 and not $1000. They also get to choose from over 100 different combinations. Not sure why this is needed, but you can.
With this also comes the need for more CPU and RAM power which the central computer does not have. So when 14 modules wake up and they start reporting at the same time, it clutters the BUS. I am guessing that is why the ECU sends a "0" state to the BUS on bootup. This resets all the modules, so they don't have to report their state except for FAULT which happens about 120 sec later. This is my first FORD in over two decades, and still learning a lot about it, but one thing I can tell you is that the ECU on the Maverick is doing several puzzling things
noticon75
Manhattan, KS
I'll nod and smile and pretend like I understand what you said! LOL. If you would have said it is all "F@(%!#& magic" Would have given the same response! I do love your mod and your knowledge to make it al work is astounding!
I think Mr Simpson had one on his computer in the nuclear reactor control room to push his enter key.
Captain
Union County, NJ
63 Nova Convertible /
What’s the chance that adding additional pulses could activate the additional drive modes that are not available on FX4 models. (Eco-Mode and Sport)
@CubanRedneck I am truly impressed with your knowledge and attention to detail, both with the mod and the video. Could you please visit any relatives in NJ and bring your tools with you. I’d love to supply you with a terrific diner at the restaurant of your choice when you’re done modding my Maverick. Great job.
Working on that! WIll be taking the steering wheel and the radio off tomorrow. I am trying to figure out which way to go on that before ordering parts.
Ok, good ideas, but how about unlatch seatbelts when put into park?
So a selector knob with detents for the drive mode selector knob which could be set to the number of button pushes for whatever the desired startup drive mode wanted.
CubanRedneck
CubanRedneck
JC
Southwest Florida
Unfortunately, it is not as simple as that. The drive mode has control over many parts of the vehicle. The transmission, injector duty, timing, and several other factors that have to be calculated as per ambient temp, barometric pressure, and an array of others. Although not applicable to the Maverick, in some vehicles, it even controls suspension and traction control. Think of it as pressing the SHIFT LOCK key on your PC before it boots. And YES, this can be achieved via software, but they have made no effort to correct it. BTW, this is not a FORD only issue. Many NEW cars suffer from the same lack of understanding of who the customer is or wants.
Telemachus
Jason
XL EB (sold), XLT Hybrid
I was able to mess around with the C302 connector (the one in your video that you mention not to use, since the resistance is different). The wire in the 7th position at the connector is the one that controls the drive mode, per the service manual. It is Gray/Violet (CYT30).
I separated the connector and stuck a tiny gauge wire into the 7th spot, and then reclamped the connector.
Touching this wire to the screw below the in-cab fuse box triggers the mode change, just like pushing the button.
So Cuban Redneck's idea (which is brilliant) can be accomplished without any disassembly of the center console at all. All you need to do is tap wire 7 and fish the wire up to a spot where you would like to install your button hack.
Fuse 6 has been reported to be ignition switched, so would be a great place to tap for power for this device, and wouldn't require going to the ignition wire in the steering column:
Passenger Compartment Fuses | MaverickTruckClub - 2022+ Ford Maverick Pickup Forum, News, Owners, Discussions
I plan to use a 7805 regulator to drop the 12V to 5V to power a PIC microcontroller that will be powered when the key is turned. 5 second delay, then 5 pulses as Cuban Redneck as detailed (one extra for the seat belt indicator) on an output pin that will control an optoisolated solid state relay that will connect the wire I tapped into pin 7 of C302 to ground.
I'll publish my schematic and PCB/components.
Ford Maverick Default to Eco-Mode with this DIY  Module 20230503_171729
Ford Maverick Default to Eco-Mode with this DIY  Module 20230503_171750
Mabcim
Rochester, NY
I too was inspired by this. I have been working on a solution using an Arduino and some Mosfets. It has taken me much longer than I wanted, life gets in the way, but I finally completed it last weekend. Now Iā€˜m working on a write up of what I did.
I am doing Drive Mode and Auto Start/Stop.
I did go to the actual switches, to be sure it is the ā€˜same’ as pressing the button; and so I didn’t have to mess with that main harness. I created a harness to put inline, so I could tap off that and so it could be removed later if need be.
I also did that so the switch can be used to configure both of those whenever you want, to whatever you want.
The Arduino I’m using can handle up to 24v, so no regulator is needed in my case.
Fuses 3 and 6 are ignition based. 3 gets power when just remote started, 6 gets power when fully started. The problem is a normal fuse tap doesn’t fit in 6. I connected to 3, and have code to get around the remote start issue. Too a bit to diagnose and understand that.
Once I post my write up, I’ll put a link in this thread.
