Start-up in Eco Mode, any help appreciated
gp1200x
Paul
NY
You built Mabcim's module, or are you using MyMavMode?
Are you positive you are tapped into fuse six, with the tap in the correct configuration?
An EcoBoost owner mentioned that these settings work without a problem for MyMavMode:
"OP is set down to 0.1, the CL is still 0.4 and the LOP is 5 and yes the remote start works also! So remotely starting then getting in truck and pushing On button with or without foot on the brake, it goes to Eco Mode too. So anything works going to Eco Mode other than when you push start to On then put your foot on the brake and push the start button again, it will go to Normal mode only."
It would appear that the EcoBoost models turn off the power to fuse six and then turn it back on again when you're going from accessory to on mode using the push button/key.
Either way, try OP 0.1, CL 0.4, and loops 5.
SUCCESS! Thanks! Those settings worked on my Lariat! I kept going with higher and longer settings and never bothered going the other way I guess. Thanks
Telemachus
Jason
XL EB (sold), XLT Hybrid
Longer settings certainly are helpful for the standard display on XL and XLT.
Ecoboost 6in screen:
Final settings for ECO Mode on Ecoboost 4 inch screen are OP 1.0 - CL 0.6- LOP 6
converseguy
2023 Maverick Lariat Hybrid, 2024 Toyota Prius Limited
While we're sort of on the topic, is there a way to get rid of the seatbelt popup after startup?
I got rid of it by buckling both seatbelts in the back seat and leaving them buckled.
gp1200x
Paul
NY
Thanks... Do you have to keep the passenger seat buckled or it doesn't matter? All these startup messages are a nusance and distraction in new cars and I doubt they really do any good.
converseguy
I did not have to buckle the passenger seat. Give it a try.
surfstar
2023 XL Hybrid
I ordered some seat belt buckle plugs from China so I can leave them in. The buckling makes the warning go right away - good tip!
vabchusa
Va Bch, VA 23452
2020 Ford Escape Titatium, 2022 Maverick First Edition
Need to get an aftermarket module called MYMAVMODE. Can be set to start up in any mode. I got one for my 22 and it works great,
eco everytime. Easy to install, took about 15 minutes.
