- First Name
- Eric
- Jul 30, 2021
- St. George, Utah
- Hot rods, Jeeps, boats
- Engine
- 2.5L Hybrid
Reading up on Forscan options I found that ALL models of the Maverick have this capability.
The "eye" (camera that detects oncoming cars for auto-dim) has other functions, including TSR. All Mavericks have this camera.
Using Forscan software and cable I enabled it easily. Here's how:
(I am surmising you know how to use Forscan. If you don't just Google or YouTube it. It's easy.)
1. Once connected choose the chip icon, then IPC Module Configuration (AS BUILT format). Find entry 720-03-02. Change the third character of the first octet to a letter C. [xxCx-xxxx]
2. Click "Write All" at the bottom of the screen and follow the screen prompts to turn ignition off/on.
3. Return to the "chip" button settings locate IPMA Module Configuration (AS BUILT format). Find 706-01-01 and change the third and fourth characters in the second octet as shown: [xxxx-xxD2-xxxxx]
4. Click "Write All" at the bottom of the screen and follow the screen prompts to turn ignition off/on.
5. On your dash display go to the "gears" icon indicating settings. Choose Driver Assistance, choose Traffic Sign Recognition and check Activate TSR.
THAT'S LITERALLY IT. You should now have working TSR indicating speed limit signs, no passing zones, etc.
I'm no expert on Forscan so I may not be able to help others troubleshoot much, but I'll try. I gained my knowledge by reading all of the (currently 18) pages of @Maverick2022XL 's thread here: https://www.mavericktruckclub.com/f...ition-tsr-forscan-mod-confirmed-working.9399/
Lots of discussion about Lariats and 6" screens so I weeded through it to find what works on the XL and XLT with the small screen. Following instructions there you can also activate other features regarding TSR.
Good luck and enjoy.
