SUCCESS! Thanks! Those settings worked on my Lariat! I kept going with higher and longer settings and never bothered going the other way I guess. ThanksYou built Mabcim's module, or are you using MyMavMode?
Are you positive you are tapped into fuse six, with the tap in the correct configuration?
An EcoBoost owner mentioned that these settings work without a problem for MyMavMode:
"OP is set down to 0.1, the CL is still 0.4 and the LOP is 5 and yes the remote start works also! So remotely starting then getting in truck and pushing On button with or without foot on the brake, it goes to Eco Mode too. So anything works going to Eco Mode other than when you push start to On then put your foot on the brake and push the start button again, it will go to Normal mode only."
It would appear that the EcoBoost models turn off the power to fuse six and then turn it back on again when you're going from accessory to on mode using the push button/key.
Either way, try OP 0.1, CL 0.4, and loops 5.
