Dash Rattle - anyone else?
bgn
WA
My dash rattle stopped completely when my winshield was replaced.
Probably because it wasn't a dash rattle, but the windshield alignment pins hitting the body. There are multiple problems at play here. 🤣
Gotmav1
Evan
Warminster, Pa
2023 Maverick
I have a very specific clunk coming from my dash possibly behind the instrument cluster. Sounds like something is flopping back n forth. It started the second day I owned my 24 Latiot Tremor. I purchased it in July this year. It now has less than 1,500 miles on it. Very annoying.
Me as well 24 Lariat! It is annoying! I do remember seeing something about a potential recall for dash rattles???
Jackfer
Jack
Central NJ
2022 maverick
And multiple opinions.
asylus
George
TEXAS
'24 Ford Maverick Lariat Tremor
I purchased mine in June and only noticed any rattles after I installed a grid in the cubby. When I dont have my phone locked into the phone mount is when I've heard it but I hope its not just a coincidence.
Phred
Phred
KC
2024 Hot Pepper Red Hybrid Maverick
Good morning, Phred. Would you please send over a private message with your VIN and dealer info so I can look into this rattle concern?
Who do I send the private message to?
Phred
Phred
KC
Not comfortable sending VIN. Not sure who
this is.
Metro Ford,
Independence, MO
Merverik
Merv
IA
NA
Also since day one in my 24 xlt hybrid BAP. I’ve have a dash rattle that sounds something like a little subwoofer vibrating the interior of my dash. Every single bump going under 35. Its on the passenger side and Is somewhat muffled if you press down hard on the dash. Very hard to pinpoint… I love my truck, but this really bums me out and drives me nuts.
AUTUS_FL
Paul
Saint Cloud, FL
2022 FORD MAVERICK XLT HYBRD;2021 HONDA REBEL 1100
After providing VIN & dealer name to Ford , then dealer to explain to me that rattle was due to loose items in the glove compartment(????), I solve it myself by shoveling down several pieces of foam behind the dashboard (passenger side). It worked so well that I went ahead and repeated steps over to the driver side.
Foam used were those that come inside the shipping box to protect a floor lamp I bought online.
My rattle noise was really critical, annoying and frustrating!! Glad it finally went away ....!
I do agree with others, this is not the place for Ford to save money.
My son's 2024 Mustang has zero rattle noises coming from the dashboard! Thats how it must be built!
Drive safe
Ford Motor Company
Official Ford Account
Dearborn, mi
Hi Merv! I can look into your Maverick's noise concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Maverick's VIN?
inline_five
2023 Hybrid XLT
04320B (4.8) ,
TEST DRIVE UNIT, HEARD INTERMITTENT RATTLE/POP NOISE DURING BODY
BEST NEAR BASE OF WINDSHIELD, ABOUT 1/4 OF THE WAY ACROSS FROM THE LEFT. REMOVE COWL TRIM AND WIPER MOTOR, CHECK AND VERIFY NO OBVIOUS SOURCES OF NOISE FOUND. TEST DRIVE UNIT.
FOUND NOISE IS STILL PRESENT.
WHILE DRIVING, FOUND NOISE GOES AWAY WHEN TOP OF IP IS PRESSED NEAR DEFROSTER VENT. ACCESS DEFROST GRILLE PANEL, FOUND UPPER DEFROST PLENUM NOT PROPERLY LOCATED ON IP BRACE/LOCATING TABS ALLOWING VENT TO POP/RATTLE DURING BODY FLEX. ACCESS IP, REMOVE AND REINSTALL UPPER DEFROST PLENUM PROPERLY ON LOCATING TABS. REINSTALL IP, WIPER MOTOR AND COWL. TEST DRIVE UNIT TO CONFIRM REPAIR, NO FURTHER NOISE HEARD AT THIS TIME. NM TIME TO REMOVE AND REINSTALL DEFROST PLENUM AS THERE IS NO LABOR OPERATION PUBLISHED IN SLTS. CODE TO 18490.
Taking back Tuesday morning as rattle/pop is still present as described in technician account.
Hopefully they can figure it out.
inline_five
2023 Hybrid XLT
Noise is definitely on the inside for me, not under the windshield cowl. The vents and the upper dash have no insulation between them as far as I can tell. Not sure how the tech removed and reinstalled anything as to get to those parts, just about the entire dash needs to be ripped apart. Very, very poor build quality and an incredibly stupid place for Ford to save money.
Yep that is what I came to the conclusion of as well. The defroster vents are rubbing the dash and causing the clunking from what I can tell. Looks like not much can be done unless you take the entire dash apart, which might just introduce additional rattling.
  • Like
Reactions: bgn
bgn
WA
The more and more "little" issues I have, the more I'm thinking about dumping it and never buying a Ford again. This is just insane.
inline_five
2023 Hybrid XLT
Got it back again yesterday. NO longer hear the rattle. Just had to re-reseat the vent work.
Do you have any details on how they did that? Would love to pass that along, and fix it for good. I assume they had to tear the entire dash apart? Any damage from that?
  • Like
Reactions: bgn
