Anybody else having the dash rattle when it’s super cold out? It almost sounds the windshield is flexing against the dash or something. Took it to the dealer and they said they couldn’t reproduce the sound, yeah ok .
Well that’s good you got the technicians to hear it. Hopefully it’s a common manufacturer defect they can put a TSB out forJust dropped mine off at the dealer today for the same issue. I live in Southern CA and it makes the noise even when it's 50-60 degrees outside. I also have a rattle in the back seat from the rear windshield. The first time I took it in they said they couldn't reproduce it so I took 2 technicians on a test drive in the morning and luckily it made the noise with them inside.
Hopefully. I have a feeling the front rattle is a windshield fit issue that will require replacement of the windshield to fix at some point (perhaps they will need to redesign the windshield to make it a couple thousands of an inch smaller, increase the curve, or use a different type of adhesive or something). Some other members on here have reported stress cracks too which is concerning.Well that’s good you got the technicians to hear it. Hopefully it’s a common manufacturer defect they can put a TSB out for
Hi there! Will you send us a message with your VIN and your local Ford dealer? I can look into things on my end.Anybody else having the dash rattle when it’s super cold out? It almost sounds the windshield is flexing against the dash or something. Took it to the dealer and they said they couldn’t reproduce the sound, yeah ok .
3FTTW8F95NRA32708, Gordie Boucher Ford in Kenosha WisconsinHi there! Will you send us a message with your VIN and your local Ford dealer? I can look into things on my end.
Mine has had a similar rattle near the Driver side A pillar since I bought it. I called the dealer , and was told it was a month out just for a service appointment. I tried removing the trim and taping any loose connectors(airbag) but it made no difference. It almost has to be the window.
The windshield already cracked on the other side, so I have it scheduled to be replaced as soon as they get one in. I'll wait and see it that fixes the rattle. If not I'll take it to Ford because it is Bad.
Yeah Ford knows about it I’m sure. Seems like where the windshield meets the dash. Definitely worse in cold weather.
Here is a video of it.
https://photos.app.goo.gl/ZwLg4gZFybMgE1zeA
Ford Technician: Good News! We found the rattle was just a marble in the ashtray!!!Just dropped mine off at the dealer today for the same issue. I live in Southern CA and it makes the noise even when it's 50-60 degrees outside. I also have a rattle in the back seat from the rear windshield. The first time I took it in they said they couldn't reproduce it so I took 2 technicians on a test drive in the morning and luckily it made the noise with them inside.
I live in Hawaii and on my 1st bumpy road had the dreaded Rattle then it went away must be the Hawaii heat because it hasn't come backAnybody else having the dash rattle when it’s super cold out? It almost sounds the windshield is flexing against the dash or something. Took it to the dealer and they said they couldn’t reproduce the sound, yeah ok .
