Dash Rattle Insights
mcrandall
Matthew
Cleveland, OH
2025 Ford Maverick Hybrid
So my 2025 Maverick XLT has a dash rattle-- seems like I'm in good company. The dealer tried multiple times to fix it without success, and now I believe that I have at least found the source, and even made it stop. What worked for me is the silly thing I did in this photo: shoved a piece of leather thong / lacing in the seam underneath the instrument cluster glare shield. By random chance I held my hand along that seem while the dash was rattling, and was amazed to discover how much vibration force was in that area! If you have the dash rattle, try placing your fingers along that seam and see if you can feel it too.
Ford Maverick Dash Rattle Insights 1768381720545-gd
Scupking
CT
2025 Ford Maverick XLT Hybrid
I have the same rattle as do probably most people... I might try something similar. I hope Ford comes out with an official fix...
John Go
2025 Maverick XL Hybrid AWD 4K Towing
I had a similar rattle fixed by the dealer under warranty. The service manager said, "There is a bracket under the top cover of the dash that was causing the rattle."
710-oil-614
Cal
2025 Hybrid AWD Lariat
I just turn the volume up on the B&O sound system (probably further contributing to rattles!)....
It's a Ford truck. They build em' rough not tough. I haven't had one that didn't squeak and rattle since....ever.
StarBug
2025 Hybrid Lariat
I turn it up until things start to rattle and buzz. 😅
John Go
In case it can help someone, the service tech said this about the repair:
REMOVE IPC AND TRIM ACCESS DASH TRIM TO INSTALL FOAM BETWEEN PLASTIC TRIM
mcrandall
Matthew
Cleveland, OH
At least you had a dealer mechanic that can do more than follow diagnostitc K1-K7 from the service manual.
jpj
Pennsylvania
2025 Maverick Tremor Space White Metallic
I fixed the rattle in this area with a small shim placed just to the left of the the leather shown. My vehicle is a 2025 Tremor. It's been three months now and the annoyance has been silent.
BLUEOVALRACER
Ravenna,Ohio
2025 Maverick XLT AWD
i haven't noticed a rattle in this area on My 2025 Maverick but if it starts this thread is helpful. I do have the annoying clicking noise from the passenger side far right dash windshield area when it's cold outside no noise when it's warm outside. That I've read on here is coming from the windshield alignment pins. I will look into them when the weather gets warm enough to work on it.
