- First Name
- John
- Jan 4, 2023
- Fort Mohave AZ
- Ford Maverick, Ford Fusion (UK), MEV Sonic7
- Engine
- 2.5L Hybrid
When I saw that the 2.5L had a 'CVT' I was expecting the 'conventual' chain belt, variable pully system. Turns out the HF45 is nothing like that! It looks very simple mechanically, 2 Motor/Generator Units (MGUs) one planetary gear set and some constant mesh gears, no sliding parts or clutches. the only mechanical bit looks to be the parking pawl. It must have some very clever electronics controlling it all.
Variable transmission seems a bit of a misnomer, the gear ratios are fixed, I've seen it described as a 'power split device' which may be a bit more accurate.
My understanding is that the anulus of the planetary gear set is connected directly to the wheels via the main traction MGU which only works as a generator when braking.
The planet carrier is connected directly the the engine and the sun gear is connected to the smaller MGU which is mainly a generator to charge the battery's, it only works a a motor to start the engine.
It is easy to see how the MGU starts the engine when the vehicle and the gear set anulus are stationary but how does it do it when the vehicle is moving, the anulus, planet gears and sun gear are all spinning, I'm guessing the small MGU applies an electrical 'brake' to the sun gear causing the planet carrier to turn and start the engine
. Are there situations when the engine has to start when reversing?
BTW will the Maverick go as fast in reverse as forward (useful for avoiding terrorist road blocks, the 'reverse spin' maneuver doesn't work with ABS equipped vehicles, I've tried it!).
Sorry if my train-of-thought piece is cluttering the forum
