- First Name
- Mike
- May 3, 2024
- KC Metro area
- 2005 Toyota RAV4, 2024 XLT Hybrid
- Engine
- 2.5L Hybrid
Since that or higher is only in the cabin after sitting in the sun, AC on.Just curious, how often do YOU deal with temperature over 110 degrees???
But I'm pretty sure I'd use the AC if it was 110 outside too!
There have been several threads thru the 2 prior summers discussing charging process and at what temp that seems to be where the system protects itself.
Since at those temps max AC is likely to be on anyway, any side benefit to the battery and getting a tad more use out of it would actually help MPG.
Of course I could see initially the ICE needing to run to provide electric to the AC thru DCDC, at least until the battery benefits from it AC running.
I'm sure it's still a net loss to MPG no matter what.
I'd sure hate to think the system is keeping grill fins closed for aerodynamics on days like that unless the AC is running full bore!
