Ramp Recommendations for Oil Changes
Hope4jsl
Jeremy
Maverick Lariat Lux Ecoboost
I think I am going to do my own oil changes on my Maverick. It has been a few years since I have done oil changes and I was wondering If I could get some feedback. 2.0 Eco (no 4K or off-road packages).
Does anyone have a ramp recommendation/link for a set of ramps your use? I prefer to get one that is low enough the maverick can clear without using any wood boards, etc?
Also, if you have a recommendation for an oil catch pan you like, that would be great also.
Any other tips or tricks regarding the oil change on 2.0 Ecoboost Maverick, let me know!
Thanks!
NJ Pinelands
New Jersey
Chevrolet
Thanks!
Ask your dealer if you can have Free oil changes for life. I have been getting them for ten years in my Chevy Colorado and am getting them on the Maverick.
Hope4jsl
Hope4jsl
Jeremy
The dealer
The dealer I am buying them from is over an hour from me and I just kind of want to do it myself anyway. I want to do them more often since it's a turbo engine and I want to make sure it's done right. I have had a couple of dealers really screw up oil changes here lately. One time they didn't tighten up the drain bolt correctly and another time they didn't screw the oil filter on correctly. They always have their least experienced guys do oil changes.
BoboysTruck
Virginia
F150, Focus, Juke
Gpp
Gil
Sanford nc
2022 ford maverick
Do what you want but i would rather have good solid wood ramps over these foreign made metal ramps.i enjoy living😁
Hope4jsl
Hope4jsl
Jeremy
Hope4jsl
Hope4jsl
Jeremy
It actually looks like most of them are now made of plastic, which isn’t very confidence inspiring.
I wouldn’t mind a wooden ramp. I was just trying to find something pre made.
LC48
Johnson County Texas
Use a screw gun with torx bit, that under cover comes off in about a minute that way.
I use two pans, one large open top with a capped spout for the crankcase and a smaller pan under the filter. Once the crankcase is draining I break loose the filter and let it drip/drain for a bit. The smaller pan I added a small "shelf" of two bolts/nuts thru the sidewall (sealed with rtv) that i use to drain the filter once it is fully off.
Also a cap style filter wrench works great to get that factory filter off - 76mm fits, push up while turning it off to keep it seated.
Take a can of fluid film under with you, then you can hit any areas of concern.
I use jack stands...
NJBob
New Jersey
Race Ramps they come in a variety of styles.
The Harbor frieght ones look like they can do the job. Most are made out of solid plastic now.
https://www.raceramps.com/
Gpp
Gil
Sanford nc
2022 ford maverick
So now they make plastic car ramps 😡oh im sure they’re really safe.
  • Haha
Reactions: HPR
JibbersCrabst
Arkansas
2013 Focus ST, 2022 Maverick XLT
I have a set of 8" lift Race Ramps that I got for my lowered car but the Maverick is within the weight range so I just plan to use those. Way better than plastic ramps and they are light weight and easy to store.
OXHB619
Clayton
XL EB 2.0
I've done the oil change on all our cars but never used ramps ever for fear that I might go too far but I was forced to get one for the Maverick because of the shield.
I went with this. I've used it once. I looked at the Walmart one but I think this one is better/stronger.
https://www.harborfreight.com/13000-lb-gvwr-portable-vehicle-ramp-set-63956.html
I own these and have used them for my Toyota and have never worried about issues of them holding up. Plan on using them whenever my Maverick finally here.
Just waiting
Gordon
Lexington, MS
2005 GMC ENVOY
The one from harbor freight is rated for 13000 pounds, I think that would cover the Maverick.
Wnbasac
Louie
Calif
Honda CR-V & firebird T/A
I bought these for my Chevy Avalanche which i sold when I bought my Mav. They’ll do just fine, i can actually use a creeper
Ford Maverick Ramp Recommendations for Oil Changes DA911A5D-1D52-4E2A-80B2-406670383022
