2024 Hybrid 2.5 engine milkshake
Mavster Mechanic
Hybrid
I checked my oil cap from cold, after 10 minutes idling from cold (temp gauge highest blue area), then drove 5 minutes down the road at low speeds and rechecked (temp gauge lowest white area), then drove 20 miles at highway speeds (temp gauge middle white) and checked again. Ambient air temps were 25-30F, original oil from factory, about 4000 miles on the odometer... not seeing any peanut butter.
Good. Because that would mean someone was sabotaging your Maverick.
It's only normal to see a form of non-edible mayonnaise.
Ryom
PA
I hope you're right, I'd hate to see a fellow member have to deal with coolant in the oil.
Hosenose
Marana, AZ
'25 Maverick Lobo
Soaps and detergents, including the detergent additives in engine oil, and the egg in the mayonnaise on your sandwich are emulsifiers. Among other things they break down oil into submicroscopic "bubbles" that will mix with water.
Stop being obtuse.
Mine did it at 10,000 miles.
Mine does it at 56,000 miles.
A little bit at 40°F.
A little more at 30°F.
Never much colder than that but there's dozens of posts that the effect is more pronounced the colder you go and the shorter the drive cycles.
One hot cycle and it's gone.
NORMAL.
Obtuse,
Being "obtuse" means someone is slow to understand what's obvious, dull, or deliberately insensitive, like not catching a simple hint, stemming from the idea of something blunt or not sharp, both intellectually and literally (like an angle over 90 degrees). It describes a lack of quick perception, making them seem stupid or dense in a given situation, sometimes implying they are refusing to see something clear.
You are very astute,
Astute describes a person who is mentally sharp, perceptive, and quick to understand complex situations, often allowing them to make shrewd, advantageous decisions.
That was a very classy way of calling someone a dumb ass. I respect everyone’s opinions. No one has to agree with other opinions.
That was a very effective way of propping up your self importance. I’m glad I could help.
:’P
My obtuseness stands.
Water, antifreeze and oil building up to peanut butter on the inside of any engines oil cap
Cannot be a good thing under any conditions.
Many have already chimed in that they do not have this condition happening in their hybrid engines.
I’d like to see a poll showing a ratio of water mixing with oil and those without.
Obtuse and Astute both correctly applied.
But
Water and antifreeze in the oil is very bad.
If it’s just in the vapor it still should not show peanut butter.
Mavster Mechanic
Hybrid
Obtuse,
Honesty is admirable.
catrikejoe
joe ramirez
2025 maverick XL
Retired 40 year auto tech that's common during cold weather driving short trips, if your losing coolant ask them to perform a chemical block test procedure that dectects exhaust gases in cooling system. It's a noninvasive simple test
cannon
mark
oregon
2022 Maverick XL awd
No kidding, I like that he thinks the service writer makes that call. Vehicle is inspected by tech, dealership warranty rep talks to Ford, and warranty people at Ford decide.
Replacing an engine under warranty can make their month, they are definitely incentivized. To call them paper pushers is just plain wrong- they aren't out in the shop twisting wrenches but there is A LOT more to that job than most people would imagine.
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
Indeed. My sister worked at a Toyota dealership while going to college, there is a lot going on there. The dealership changed owners while she was there, a lot changed almost overnight. Some of it fishy, some of it legit, it all comes down to how the franchise ownership and managers do things.
Propane Burning Man
Will
Gold Hill, Oregon
24 Maverick Lariat, 007 Mustang GT, 2015 Propane Transit 150, 1970 VW Dune Buggy
My experience is with 2 blown head gaskets back in the late '70's and early '80's. Both times my first indication there was a problem I could smell antifreeze in the cab because the compression leaked into the coolant system and blew antifreeze out the over flow tank. Antifreeze was not in the engine oil. You will not go far with a blown head gasket blowing the coolant out. I doubt OP has a blown head gasket. For what its worth my oil cap looks fine. My typical trip is 35 miles. 20 of that is freeway. And I live in a mild climate. Keep in mind typically 1.5 gallons of water goes through the combustion chamber with every 1 gallon of gas burned. Surely some of that gets past the piston rings.✌
Chops
Lobo
I did not realize there is that much water - thanks! Of course, that water is a byproduct of combustion and not coming from the the coolant system.
But still another reason for us “short trippers” to change our oil per the “severe use” interval.
Sure, our OLM is supposed to recognize that severe use and calculate oil life remaining % accordingly….hopefully it is more accurate than the “miles to empty” calculations;)
Chops
Lobo
Does the “mayonnaise” form more when driving or in the garage sitting after a drive?
It it forms while sitting and cooling down - would it make sense to remove the cap after a drive & wipe it clean? Then replace the cap. Do it often enough and no mayo?
Remember, I’m the occasional EB oil cap sniffer - keep that in mind as you flame me:)
Mavster Mechanic
Hybrid
That's the procedure if you have the occasional OCD.
Bobkath
Prescott, AZ
BMW Z4 roadster ,Highlander 24 pepper red hybrid
I am not an engine expert, however I have made countless trips of 2 miles or less in less than 30 degree weather. Just checked the oil cap and it looks perfect. If I saw what the op saw, I trust cherokee's advice and get it back to the dealer. I just couldn't resist saying something after reading all the pages on this. Besides the extra furr in the engine compartment made my day.
Have you noticed any abnormal white smoke from the exhaust? Definitely does not look good that's for sure.
Confirmed no white smoke on the next colder morning when it would run a bit longer - so that means open loop even during the cat warmup.
No - the other non-furry cat!
