2.5 hybrid engine requires Premium Gasoline?
olderbudwiser
did you get one? We went through something similar trying to get a ps5 - what a pain in the ass!
Just had a new Costco grand opening on the 9th of December. Opened at 0730 local paper said people lining up 0330. Guess they really wanted a Ps5 whatever that is??
Darksider
Here
Two
13:1 would require premium in a context. If it was dynamic compression (running compression) but like stated before the valves close late in the compression stroke which will bring down ratio.
The 13:1 is static compression which means the piston at bottom and valves closed compressed to piston at top. Which even non Atkinson engine don't run static compression.
Decayed
yes
a car
sony playstation 5 gaming console. Basically unobtainium.
olderbudwiser
I have to assume those waiting in line knew there were some of these in the new store.
inferno
Ron
2009 Chevy Colorado, 2022 Ford Maverick
You must be in Brevard. I haven't even attempted to go anywhere near Cosco yet!!!
Decayed
yes
a car
Yes there are places that track when they drop so people can get them. Even if you have advanced notice you can't even log into the website fast enough to get one. It's insane.
olderbudwiser
Almost like trying to get a Maverick Hybrid :cool:
Proflig8tor
Atlanta, GA
Gulfstream / Grumman AA5B
87 Octane fuel is recommended by Ford and the better fuel for a 2.5L Atkinson cycle engine. The lower octane fuel has a higher energy density per unit and would provide ever so slightly better mileage in the Maverick Hybrid. (Guessing 2%) The Maverick Hybrid is a very lowly stressed, reliable, system with components that have been in production for 14 years. The 2.5L is really overbuilt for this application and lives an easy, stable, life with the electric motor taking up the slack. This engine combo won Ward's 10 Best in 2010.
87 Octane in a turbocharged EcoBoost is not a good idea. The knock sensor should trigger a reduction in boost in time to avoid engine damage. As a result, the EcoBoost will be down on power and potentially be less efficient overall since it is not running at its optimum boost (compression) levels.
I attended the R&D tear-downs of the original EB V6's. The fact these things survive is really a miracle of materials science and wicked smart engine controls.
Benson
Benson
Maverick Hybrid XLT
That's what this thread is all about. And the answer has been given: NO. It requires only 87 octane.
According to "First Ford" post, he wouldnt put 87 in his 13.5-1 motorcycle so now i plan to use 91 octane in the Mav.
fbov
Frank
Bushnell's Basin
2020 Escape Hybrid
You know the Maverick's 2.5L Atkinson will only use 90% of that 13:1 compression ratio?
13:1 is a geometric calculation that ignores Atkinson's reduced intake volume. I agree you'd need premium, in a motorcycle because it's a conventional engine. Not so much at the Atkinson's actual ratio of more like 11.5:1, or less. (Atkinson ratio varies as far as 50% fill).
FirstFord
Massachusetts
VW Jetta
I think you missed a critical difference. My motorcycle doesn't have an Atkinson cycle motor. So the moto sees a real 13:1. The Maverick does not because the intake valves are open for part of the compression stroke. The air-fuel mix in the Mav never sees 13:1.
I will use 87 octane in my hybrid Maverick (if I ever get one).
Benson
Benson
Maverick Hybrid XLT
Oh, ok....thank you for this clarification on the 87 octane......I will also use now.👍🏻
slooose42
Sacramento, California
Toyota Tundra 5.7 4wheel drive
I saw, in the fine print, somewhere on the information of the hybrid that the 40 something miles per gallon was with premium fuel. What, a 13 gallon tank and 10 cents more per gallon, $1.30 more per tank..........I'm going for it.
bombast
Pennsyltucky
2022 Ford Maverick XL, Hybrid
Where, exactly, did you see this 'fine print.'
