- First Name
- name
- Jan 13, 2022
- hinterlands
- 2022 Ford Maverick XL, AWD, 4K tow, 2.0L EcoBoost
- Engine
- 2.0L EcoBoost
Note I haven't tested this yet to see if it actually works but I can enable and select it in the vehicle driver assistance options.
This mod so far is confirmed selectable using a 4 inch cluster on 2.0L ecosport. engine. FWD / AWD shouldn't matter and neither should trim level as long as the cluster is the 4 inch version.
First we need to enable this in the IPMA. It may also require TSR to be enabled but I am not disabling mine to test. The IPMA setting may also be different for vehicles with GPS NAV systems installed.
IPMA
706-01-02
xxxx-*xxx-xxx
* = 6
This will enable it without errors
* = 9
This enables it also but knocks out the pre- collision assist. This maybe correct for vehicles with GPS Nav systems installed.
Next we need to enable it in the cluster
IPC
720-09-02
x*xx-xxxx-xxxx
* = 0
off
* = 8
on
That is it and you should see it under the vehicle assistance settings and the mode should also be selectable using the steering wheel switch.
IPMA
706-01-02
xxxx-*xxx-xxx
* = 6
* = 9
IPC
720-09-02
x*xx-xxxx-xxxx
* = 0
off
* = 8
on
