Why have a tachometer
Shawshi
Graham
Idaho
1980 F150, 2002 Firebird, 2025 Envista
Why is there a tachometer In the Maverick EB? With an automatic transmission that you can't change gears what is the use?
I sometimes glance down at it to see if the auto start-stop has activated but that's it.
Any ideas what would be a better use of the area taken up by the tach or a better way to indicate auto start-stop is activated?
gte105u
Katy, TX
Keeping an eye on the tachometer can help gauge how you are driving for fuel economy. Also good for when towing to keep an eye on how hard you are pushing it. But ultimately they don't have a lot of use outside of towing and sports cars.
AzCactusGray
Tucson
C5, SC430, 67XKE, 08 XJR, 78 F250, 22 Mav
..... I remember the days of almost no gauges and other than the speedometer, just idiot lights... It was a very dumb idea. I'll always go with gauges even if they're not needed like they once were. The best thing in that space is, if not a Tach would be other gauges, water temp, oil temp, transmission temp etc. Ideally, with the ability to scroll through those gauges including a Tach.
Jakb
Jak
Minneapolis, mn
23 XLT Hybrid
For me it helps diagnose issues.
Weird rough idle? Boggish acceleration? Loud revving noise? No revving noise? Surging? Ignition wobble? Heating up on a downhill? Bat not charging?
It's not super applicable in nice new cars, but once a vehicle hits 100k+ miles it does definitely come in handy.
Shakesbear
J. R.
Good points! My experience driving ( only 57 years ) is that the sweet spot for max speed and efficiency on virtually every car I’ve driven, is at 2000 rpm’s on the highway. If you have the ability to drop the transmission into a (L)ow gear, you better keep an eye on the tach 😉
Clock Doc
Mass
Ford Maverick 2.0 ecoboost, Ford Crown Victoria
All the above.
I remember those days too when they got rid of the gauges and went with trouble lights only. Some of them came back but not all. I miss having a voltage gauge.
Timothyd
You can use it as a diagnostic if somethings wrong.
thevol
GA
Iconic Silver Mav 2.0 AWD 4k
Are you suggesting Ford remove the tachometer? Thats an odd request on an ICE vehicle
BlueSnake77
Rochester NY
Wish they would put more gauges in cars now, load it up like a semi truck, I want to monitor everything.
It's pretty sad the lack of gauges in modern cars. My 1985 Plymouth Voyager minivan had a voltmeter and oil pressure gauge.
Decayed
yes
a car
easy way to tell if the engine is actually running and if the transmission is working properly. if you are going 20 mph and it's revving to 4k rpm something is wrong.
dalola
Retired
SE Ohio 🇺🇸
Agree. As an older racer/hotrodder, I just like to monitor status of all the mechanical systems of a car, even tho these new ones take care of everything themselves.
I was driving in 109° temps in 75mph zone but since I had no idea what temps were doing (battery, transaxle fluid, drive motor, generator motor, etc) I dropped to 66mph which seems to be a sweeter spot (had very little wind also). If nothing else I felt more comfortable and had no fears of speeding up due to traffic until the next passing zone when necessary.
Gpp
Gil
Sanford nc
2022 ford maverick
It’s to keep us old driver’s happy if nothing else.you younger drivers get your technology stuff and we get a tachometer.all vehicles should have one🙃
