First oil change (rounded kilometers, not exact conversions)
  • Total voters
    579
DryHeat
DryHeat
Arizona
Jeep Patriot
I've heard (and followed) the advice to "vary the engine speed" during break-in.
But... I'm wondering how that advice works out with a hybrid and an eCVT. I had a regular CVT some time back and it seems like the RPM stayed pretty constant whether I was going 50 or 70. It changed sometimes on hills, but I'm not sure I want to go looking for hills just for break-in.
Anyone have any info on how this works with hybrid-eCVT?
BDennis
Bruce
So Cal
Good point
Sliphorn
Missouri
2022 Ford Maverick XLT Hybrid
Works the same way but perhaps a good idea to do a fair amount of acceleration/deceleration. Gas on gas off. Doing that loads things up which is what you want.
Edge Haley
Edge
CARBONDALE-Atlanta
PORSCHE
I'll change my oil according to the manual.
Seems so absurd not to follow the Owner's Manual. I've picked up at least 12 vehicles directly from the manufacturer of the car, each time doing a walk-around on break-in recommendations - their parting words were always, follow the Owner's Manual...
the manufacturer should know better than anyone else on the planet what is best during a break in period....and what spec motor oil to use....would make no sense for them to give bad advice.
Rob Cactus Gray
Rob Cactus Gray
Robert
Sierra Vista AZ
11 Prius
Planned obsolescence.
mav_can
BMW X3, 2018 Mustang EB Premium
I get what you're saying, but manufacturers also warrant their cars for years. The only scenario where the owner's manual is not the best maintenance schedule is if an issue in that first 1000 miles somehow stays totally undetected until 5 years down the road. The chances of such an issue seem astronomically low to me.
Rob Cactus Gray
Rob Cactus Gray
Robert
Sierra Vista AZ
11 Prius
You’re assuming they will fix a small issue under warranty. My Prius manual says 1qt per thousand mile oil burn is normal.
manuals have said “lifetime” fluids before too 👌. Lifetime only has to be longer than warranty
thunaman
Andy
Peoria AZ
2017 Subaru Outback
Honestly oil filters can get particles down into the microns, 20 or so I believe. I'm super OCD and will be keeping this truck for 10+ years so before pickup I'll be getting some magnets to pop on the pan if its not composite, a magnetic drain plug after the first oil change, and filter magnets as well.
Also some liquimoly friction modifiers into the oil. Also will be doing a transmission fluid flush at 10k with a change or clean up of filter for that too. Heck throw some magnets on the transmission too...
http://www.filtermag.com/
Keep in mind that the engine is Aluminum which is a non ferrous material and as such a magnet will not remove pieces of aluminum from the oil. this is not to say that a magnet is a bad idea its just not foolproof.
TRUCKHEF
SOCAL
22' Ford Maverick XLT
you are 100% correct the block is aluminum but many other wear parts, camshaft, crankshaft, piston rings, oil pump/chains and whatever else may be there usually are ferrous, I'm going to be as OCD as possible and throw magnets wherever I can.
Brian_J
Akron, Ohio
'22 HPR Maverick AWD 4K LUX
Check out dimple drain plugs. I’ve put them in 2 cars and 2 motorcycles now and they have STRONG magnets!
Decayed
yes
a car
Follow the manual, what else? I will take it easy the first 1000 miles as they suggest, but I will change the oil around then. Can't hurt, might help. After that the goal is do what the manual says, error on the side of safety.
The newer oils are really good. Unless you beat on it you should be fine.
oldfatguy
tom
1997ranger 2006 fusion 2001 bmw330ci 2004.5w3500
drove normal ,i live in a rural area so no high speeds involved , i changed oil yesterday with about 1500 miles on it , i will have lots of short trips so the plan is 4 to 5 k miles running good full sythetic for the next 200 plus k miles
Kenny
Kenny
2022 Maverick XLT 2.0 Ecoboost with AWD, Tow Pkg
Used to change a new vehicle at 500 miles, but with synthetic oils that are so slick the manufacturers put special additives in the oil to aid in break in.
Excellent point. My first brand new car was a Honda Civic, and thinking to take the best care possible, I switched to full synthetic right away, around 300 miles. Over the next few months I was getting terrible fuel economy. Finally one day I was talking to a mechanic, and he told me it was because the synthetic oil was not allowing the engine to properly break in. So I switched back to a standard oil for the next 3000 miles. My fuel economy improved dramatically. The next oil change I went back to full synthetic and have been using it ever since. The car now has 107,000 miles and never needs oil added between oil changes.
RicksMaverick
Rick
Westfield, IN
Rapid Red 2022 Lariat Lux 1$tED 4k AWD
