What's your oil consumption like?
The Real Maverick
Jack
Well, inconclusive circumstantial evidence is some people fill high and some people lose oil level and a lot of those are the same people.
If there is nothing to be gained from filling high other than you can go a longer interval without checking up on it....
Tbone289
MO
That's interesting logic...
I can tell you that I've run many vehicles for many miles at or near the full mark with no notable consumption and excellent gas mileage. I guess I've been lucky that all of those vehicles had the full mark in the right part of that "indistinct area".
With today's incentives from the EPA and CAFE, how many vehicles do you think are being manufactured with oil windage issues? It certainly doesn't appear from this thread that the Maverick has those issues since there's exactly one participant that has reported notable oil consumption.
d7602002
Joseph
2024 Maverick XLT
I'm confused when it comes to oil. I thought the w stood for winter, not weight. And that the first number indicated the viscosity when cold, so lower the number the better. And the second number represented the viscosity when it was operating temperature. But I hear people talk about the weight of oil so I'm not sure.
And then if the manual says one quart for every thousand miles is normal, that just seems ridiculously wrong. So you go on a 5,000 mi trip and when you get back you have a half a quart of oil and they consider that normal.
Tbone289
MO
You're not confused at all. The w stands for winter, and the lower the first number, the better the oil flows at lower temperatures. The second number is the base viscosity, or the viscosity at operating temperature. "Weight" is just another term people like to use for viscosity. "w" and "weight" are unrelated.
Stating that 1 quart consumed every 1,000 miles is normal is just CYA from the manufacturer to keep from replacing the odd engine that consumes oil for whatever reason.
HenryFord
MO
I have seen a lot of OEM's pull out the 1 qt per 1000 mi out of their backside when they know they have a problem. And sadly it isn't as uncommon as many would think. It is all CYA by the OEMs when people start reporting excessive oil consumption.
OleFordGuy
Mine hasn’t used any. Change every 5K miles always stays on full mark on dipstick, use 5W-30 Castrol Full Synthetic oil and motorcraft FL-910S filter. IMO if your having to add oil between oil changes something’s not right unless you’ve got hundreds of thousands miles on the engine
Jalopy Technology
Jalopy Technology
Rick
Central Wisconsin
'25 Maverick, '04 LeSabre, '99 Grand Cherokee, '88 F350 crew cab, '65 Dodge Coro
Just wondering how much oil you Eco Boost consumes... I had to add a qt after 2000 miles at roughly 9500 miles total .
Not worried just wondering.
I may try 10W30 oil on the next change to see if it changes.
800 miles since I added oil and it is still on the full mark.
Cherokee
Here’s my experience so far with the new 2025 EcoBoost — honestly, this engine is a beast across the full RPM band. I love the torque, especially how it sounds and pulls at low revs.
1st oil change: at 495 miles (break-in flush) — replaced the factory Motorcraft oil with a Group IV full synthetic. Zero oil consumption.
2nd oil change: at 5,005 miles — about 300cc of oil used during the interval.
3rd oil change: at 13,015 miles — around 600cc consumed.
I always top off and keep the oil right at the MAX line (or just 1mm below).
For now, I’m very impressed with this engine’s balance, performance, and oil control.
No complaints
My Ecoboost, “across the full RPM range,”
A Beastie she is.
A very good analogy.
1st oil change to MotorCraft Full synthetic at 3,000 miles, Zero oil consumption.
At 5,700 miles and still Zero oil consumption.
2nd oil change will be at 9,000 miles.
Then 15,000 and every 5,000 from then on.
I’ll continue to feed Pepper Motorcraft products of the Full synthetic flavor.
happyfer22
Fernando
Carmel NY
2025 Maverick XLT (no GPF....)
Here's the thing. At least I think it's a thing.
People who add to the max. line lose more oil than people who keep it at the min. line.
Remember, anywhere between the two lines is acceptable, and in general, this is a case of more ≠ better.
Sure... for personal mental comfort, running it on the high side "feels" better. But it's not better for the engine as long as you don't go too low.
An extra quart can cost you 0.5 MPG too. While not a lot it will add up in 100,000 miles.
Let’s get something straight here.
Suggesting that running your engine at the MIN mark is “just as good” as being at MAX is mechanically incorrect and potentially harmful — especially when others might take that advice seriously.
Ford engineers didn’t design the EcoBoost MFC to take 6.1 quarts just for fun. That full capacity ensures proper lubrication, thermal stability, and pressure across all critical components — especially under load, heat, towing, or aggressive driving.
The MIN mark is just that: the minimum safe threshold to avoid engine damage — not the recommended level for long-term use. Running 0.5–1 full quart low increases oil temps, reduces film strength, and raises wear rates over time. I’ve seen this first-hand in high-mileage fleet engines.
And this idea that topping to MAX somehow causes oil loss or hurts fuel economy? Show the data. Otherwise, it’s just baseless speculation.
Not trying to start a fight — but when you throw around engine advice that others might follow, at least make sure it’s backed by facts, not just “feels better.”
happyfer22
Fernando
Carmel NY
More slop, sling, slosh, splash, in other words, more friction at the high mark vs. the lower mark? Absolutely.
It's not an exact or precise cutoff. But a gradual effect that can include some or all of the following:
Extra engine oil can create excessive pressure within the crankcase, potentially forcing oil past seals and gaskets, causing leaks & oil consumption
When the crankshaft churns the excess oil, it can create foam, which doesn't lubricate the engine as effectively as liquid oil. This can lead to increased friction and wear on engine components.
Excessively overfilled oil can also lead to issues like spark plug fouling, catalytic converter damage, and unusual engine noises.
There's not a distinct line when this happens. But there is a distinct line on the dipstick. Which is a bit of a misnomer.
Let’s clear this up: “Full” isn’t overfilled. It’s the OEM-recommended level — tested for proper pressure, lubrication, and cooling. If the crank was foaming oil at that mark, Ford would’ve moved it lower.
Running below full is fine, but suggesting the max line causes harm is just misinformation. Especially risky advice for towing or hot climate
The Real Maverick
Jack
Let's reiterate what I said, and this may help you out:
Ford Maverick What's your oil consumption like? 1751902372552-u0
Adding oil so it is over the "full" mark is too much. Your MPG and engine wear will suffer from minuscule to severe depending on the amount of over-fill.
Running with oil below the "add" mark is too little. Your engine wear will suffer from minuscule to severe depending on the amount of oil it is too low by.
Circumstantial evidence from 100's of blog posts suggests, but does not prove, the higher the level of oil routinely in the sump, the greater the overall loss / consumption will be for that driver.
Now, if you can't understand any of that, it's unfortunate for you, but no skin off my nose.
happyfer22
Fernando
Carmel NY
Thanks, but I’ll stick to OEM specs, thermodynamics, and engineering logic — not “circumstantial blog evidence.”
Oil at the MAX line is exactly where Ford engineers calibrated the system for optimal pressure, cooling, and lubrication balance.
Ford specifies 6.1 quarts for a reason — and “MIN to MAX” on the dipstick is a usable range, not a performance target.
If someone has peer-reviewed data proving otherwise, I’m all ears. Otherwise, let’s not confuse the forum with folklore.
Best, ✌
The Real Maverick
Jack
People who see Bigfoot see something.
They are not making it up.
Most are bears walking on two legs.
Occasionally it is a person in a costume.
But people believe what they want to believe.
Does your "OEM" manual say fill to the max line every time? Or is that your personal belief?
Actually, you don't need to bother answering. The manual calls out anywhere in the cross-hatched area as "normal".
The cross-hatched area is from zero to about 75% of the range between minimum (add) and maximum.
From OEM Specification (it's in your manual):
"IF THE OIL LEVEL IS BETWEEN THE MAXIMUM AND MINIMUM MARKS DO NOT ADD OIL."
I don't think I've posted anything contradictory to the OEM users manual.
Best. ✌
No complaints
I can't recall years or makes - but years ago when synthetic wasn't a huge thing but easily found - I dealt with someone's car that called out NOT using full synthetic until after so many miles on the mix (well past break-in miles mentioned), and it seems even called out the factory oil left in for the full break-in period, not swapped early.
Research later suggested they said that was for proper ring seating.
Is that still a thing?
The few stories at the time, of going back to OEM mix for additional miles to stop excess oil consumption, were given.
