Towing capacity for the 2.0 Ecoboost XL?
NorthernNic
Nic
Mavtruck24
2009 GMC Canyon / 2024 Maverick XLT fx4
imo 4k tow package is best in value even if you don't plan on towing much it will have better resale value and you get alot for your money.
TwoTone
MD
Outback 3.6
Yup I had to cancel my original order. Never planned on towing that much, but decide to add it. Before I could call, I got a VIN and schedule date. I was shocked it only took 1 day.
FamousAmos
GAB
Maryland
2022 Maverick Hybrid XL
We're trying to tell you that the capacity is 2k pounds. That's it. Nothing more.
In a related question, does the 2K hitch come with the 4-pin wiring setup, or is that extra?
Oscarcat
Eric
Encinitas California
On the Maverick I believe the tow package includes a brake controller, larger radiator, transmission cooler and different trans gearing. Don't think you can add a "tow package" and get the same kind of engine/trans protection as a factory 4k tow package. You may want to think about trading in if you must tow up to 4k pounds.
...and doesn't the 4k tow pkg require AWD? I haven't checked but my recollection is 4k pkg wasn't available on FWD Mav's.
NoVaJimmy
KCMO
Lexus GX 460
If you choose the factory hitch option it comes with the 4 pin wiring and connector. From what I understand, if you don't choose the hitch option and want to add a hitch later you need to add a wiring harness for the trailer lights as there is no wiring present like on other makes and models.
NoVaJimmy
KCMO
Lexus GX 460
Yes, 4k towing requires AWD
TNFurb
Kelly
Nashville
‘23 Bronco Sport OB ‘24 Mav Lariat Hybrid
I have the 2022 XL-FWD EB which pulls 2000lbs. Sufficient for my needs of hauling a 1500lb cargo trailer, and still gets 18mpg keeping speeds between 65-70mph.
However, I did a bad thing today...
...and ordered a '24 Maverick XLT with the 4K tow package. It's time to do the Maverick "Hurry Up and Wait!" dance.
You might be surprised that it won’t take as long as you think. Also I am seeing more 24 Lariat’s arrive at dealer lots only to be abandoned by the original orderer so I would recommend keeping a watch out for them if you want it sooner than later. Congrats on getting a newer one though!
catshreds
Roland
2023 XLT AWD
if it had a 7 pin n built in controller I’d had something to go by it literally has nothing. That’s why I’m trying to figure out what the capacity is so I know what to buy. For it I was told it could tow 4k when I bought it but nothing. Anywhere says that.
Wow! Seriously?
FamousAmos
GAB
Maryland
Yes. The $100 Hitch option includes 4-pin wiring/connector
Thanks, guys! That's what I wanted to hear. I hadn't bothered to look under the truck, as I only used the hitch for my bed extender. But, now that I am VAGUELY considering a small trailer, I am concerned about the existence of the 4-pin electrical hookup.
CajunMick
Heman
Houston, Texas
2023 XLT Maverick
My XLT AWD sticker clearly has the 4,000# towing capacity noted. And ID the gear ratio. Physically, it has the brake controller controls, similar to what I had in the old F250. Also has bigger receiver hitch, the 7-way trailer light /brakes plug in receptacle on the bumper. And when prompted , selection for “tow mode” on the dash display.
As for a transmission cooler, I haven’t look into that, cannot verify. It might be the exchanger built into the radiator, or maybe a separate inline air cooler of sorts.
Will I ever tow? Prob not. Only time would tell. But will be ready if and when a need to tow.
BlueRaven
Iowa
24 Mav, 01 CRV
trailer hitch 2k. trailer hitch with the trailer brake controller built into the dash 4k. there you go easy way to tell what yours has. or you could have just called your dealer, given vin, then bobs your uncle and they would have told you.
