The “L”ow Down (shifting into L - Low when approaching a stop)
Moorparkmark
Moorpark CA
2024 XL Hybrid
I recently consulted ChatGPT on a question I had about using the L transmission setting when I’m approaching a stop sign or red light.
For those of you not familiar with ChatGPT it is in AI based data repository that essentially searches all available data on subjects and provides the detail you have requested.
Here is a response I received:
Yes, it’s generally okay to shift your Ford Maverick Hybrid into “L” (Low) when approaching a stop, but there are some important things to understand:
What “L” Does in the Maverick Hybrid
  • On the Ford Maverick Hybrid, shifting to “L” increases regenerative braking, which helps slow the vehicle down more aggressively and charges the battery.
  • It doesn’t lock you into a single gear like in traditional automatics — it’s more about changing the vehicle’s behavior to prioritize engine braking and regen.
When It’s Useful
  • Approaching a stop or going downhill: “L” can help slow you down more quickly, reducing brake wear.
  • Heavy traffic or city driving: If you want to make more use of regenerative braking and improve efficiency slightly, “L” can be helpful.
  • Steep descents: It gives you better control without riding the brakes.
Things to Keep in Mind
  • Shifting into “L” at low speeds (like under 30 mph) is completely safe.
  • Don’t downshift abruptly at high speeds — it won’t harm the vehicle due to built-in safeguards, but it’s unnecessary and may feel jerky.
  • Using “L” all the time isn’t harmful, but it may make the ride feel less smooth in normal driving.
Bottom Line
✅ Yes, you can shift into “L” when approaching a stop in your Ford Maverick Hybrid. It’s safe and can even be beneficial in some situations. Just don’t treat it like an emergency brake — use it for controlled slowing.
It should be mentioned.
Selecting L on a Maverick hybrid,
like selecting a lower gear on an automatic transmission or downshifting on a old school manual transmission it does not activate the brake lights.
And
The engine RPM's will let you know when the battery is full.
Gray Goose
RG
Wissota
Slowing aggressively without brake lights sounds like a good way to get rear ended. Lots of posts about the Maverick tendency to get rear ended. Curious if "L" might be a factor.
scpowered
Sam
'25 Maverick Lariat AWD Hybrid - '18 Jeep Grand Cherokee High Altitude
This was my thought also. I have a hybrid and I like to use "L" to slow down, this way I know I am using regen and not the brake pads. BUT I ALWAYS make sure there is not a car behind me!
Before I realized the brake lights did not come on, I had noticed cars approach very quick and then slam the brakes! At first I would get mad at them for almost hitting me, but that is when I realized what was happening and that I was causing the problem, AND I had to be careful when I use "L".
Meeka
Jay
Castlegar B.C. Canada
2024 XLT 2.0 turbo
Of course this doesn’t apply to the EcoBoosts! 😉
jerrisn
NE
2023 XLT Hybrid/2025 Explorer/2018 Volt/2011 Fusion Hybrid/08 Tundra/00 MustanGT
The "L" (Low) mode in the Ford Maverick enables one-pedal driving, a feature common in electric vehicles (EVs) and hybrids, including my 2013, 2015, and my daughter’s 2018 Chevy Volt. This mode allows drivers to accelerate and decelerate using only the accelerator pedal by engaging regenerative braking when you ease off the pedal, slowing the vehicle.
One-pedal driving is most useful in stop-and-go traffic, where I rely on it frequently. However, I avoid using it at speeds above 50 mph in my 2023 Maverick. On highways, releasing the accelerator in L mode causes the vehicle to decelerate more quickly than when the mode is off, requiring more energy to regain speed compared to coasting. While it doesn’t harm the vehicle, I prefer to disable it at higher speeds for efficiency.
In town, L mode shines. With practice, you can master feathering the accelerator to coast smoothly to a stoplight, nearly coming to a complete stop. However, L mode won’t bring the vehicle to a full stop, so the brake pedal is still necessary for complete stops or emergencies. Always use the brake when needed for safety.
jerrisn
NE
Like selecting a lower gear on an automatic transmission or downshifting on a old school manual transmission it does not activate the brake light.
The engine will let you know when the battery is full.
I haven’t confirmed whether the Ford Maverick’s L driving mode activates the brake lights, but I believe it does. In newer hybrids and electric vehicles (EVs), including my daughter’s 2018 Chevy Volt, the brake lights activate during regenerative braking in one-pedal mode. Older models didn’t always do this, but I think a regulation now mandates it for safety.
Ryom
PA
2025 Lariat 4K BAP Eruption Green
(L) seems like it keeps the eCVT in a lower "gear" for the ICE engine for improved engine braking. So I'm a bit skeptical of it actually improving around town efficiency as the engine hangs out in a higher RPM range with it enabled versus not.
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
It does not. Drive at night and watch out your review view mirror.
Ten minutes ago.
With the assistance of my wife, I reconfirmed pushing the L button to slow down on the hybrid Maverick does not activate the brake lights.
jerrisn
NE
I owned a gen 2 Volt. Yes using the regen paddle on the back of the steering wheel. Activated the brake lights. My gen 1 did not have a regen paddle to increase regeneration you just pressed starter on the brake pedal.
I roped my wife into this experiment. Pushing the L button on the gear selector does not activate the brake lights on the Maverick.
I'm surprised it doesn't activate them. I use it regularly in town and I have not had an issue with anyone behind me.
