Boxster, Yamaha FJ1300, Maverick XL
Yeah, that kind of explains it.
Hi, I installed my tailgate assist with the damper in the upper side and the arm to the bottom, I noticed you installed it the other way, maybe that's why you were having the issue, Mine is working fine after 2 months of use.
Wrench77
New Hampshire
Cadillac ATS, Ford Maverick pre ordered
Your better off with the chrome end of the piston down that way it won't collect dirt and drag it into the seal prolonging its life. It will wipe the dirt off and gravity will take care of the rest.
LADemien
Lonnie
Eufaula, Alabama
2022 Ford Maverick Lariat 2.0 AWD
Everyone who has stated so is correct, the barrel of the assist goes up and the rod down. There is a mechanical reasoning behind this configuration. On the inside of these gas assist shocks there is in addition to the gas, a liquid lubricant. The reasoning for the positioning is so that the lubricant can keep the rod end seal from drying out and leaking.
Fastbackjon
Jon
Iowa
2022 Maverick XLT 2.0, 18 Flex, 20 Edge, 21 Escape
Excellent explanation-totally agree with you. Though I don't get why there are pics of these closers out there showing them with the rod up on other makes and models.
KeinoDoggy
Elliot
Ohio
2022 Maverick Hybrid and Outback
bbhaag
Wakeem
Jay
New York State
Ford Maverick, Hyundai Kona
Does anyone have any other places or uses where they put the bottle opener that had to be removed?
Also want to mention, what a pain getting that lower ball mount installed, they could have made that much easier. I thought I had to be doing something wrong until I looked it up and saw it is just poorly done and overly glued locking bolt.
dadd75
Upstate South Carolina
www.universityofheaven.com
2022 Maverick Hybrid Lariat, 2013 Buick Encore
The 20% off is only good for one time. I forgot to order the dampener, and tried to use the 20% off coupon code again and it was rejected.
Mymaverick2021
Steveo
Hilo Hi
I discovered that to avoid the rubbing you have to be sure that the metal plate that the rod attaches to is exactly straight up and down. Your picture shows that the bottom of the plate is jutting out slightly towards the tailgate. Mine was at first and I experienced the rubbing. Once I reposition the plate correctly my problem was gone.
Good catch, Looks like I F'D up installing my top plate I'm getting that rubbing on the back of the cable will make the proper adjustments
Ford Maverick Tailgate soft close fix 20220820_133115
Ford Maverick Tailgate soft close fix 20220820_133423
jons
Jonathan
1989 Ford Bronco Eddie Bauer
Update, Plate now straight no more cable pinching
Good catch! Thanks also for documenting and sharing with the rest of us so we can also see pictures of what it supposed to look like!
clavicus
Mymaverick2021
Steveo
Hilo Hi
Also as you see in the picture the correct end of the soft close shock has the fat end up
Seriously, there is never a reason to order from the ford main site that I can think of. The dealer sites like this literally have everything off 18-20%.
If it's something large/heavy then the free pickup option may be worthwhile vs shipping costs.
