Tailgate cable/gate continutes -
Bj517
Nc
Lariat
I can probably get close, but it is longer than my calipers would measure. Let me go take a look
Oh tape measure accuracy would be plenty! I'm just curious as mine (truck built feb 2022) seem to be a good 3/4"+ too long
OXHB619
Clayton
XL EB 2.0
looks to be Drivers 14" and Passengers 14 1/8"
measured from the grommet clip end to the other clip end, so the wire in-between each hook/clip/connector
OXHB619
Clayton
XL EB 2.0
Ford Maverick Tailgate cable/gate continutes - 1666314913180
measured at that crease, where the actual metal starts under the heatshrink on each end.
Nw_adventure
Nw_adventure
Salt Lake city
I also noticed the newer cable has a much different shrink wrap at the joint than what came on my rig with a 5/23 build date. FYI
Bj517
Nc
Lariat
Yup as expected, measured from the same spots, mine are each about 14 3/4" or even a hair longer
Best measurement to eliminate any variance in actual end fittings would be to measure the distance from the far sides of the holes in each end as that would be the actual needed length with the tailgate in it's preferred level positions
OXHB619
Clayton
XL EB 2.0
I’m out of Texas for a week, I’ll check when I’m back. I did those measurements at night too because I was impatient, I can try to be more precise.
I figured the connectors were less likely to be a different size vs the cable from crimp to crimp.
Mymaverick2021
Steveo
Hilo Hi
Just picked up my Hybrid yesterday. It seems much more level visually than my XL, I have not used a level or 2x4 to verify.
Now that's the way it's supposed to be, I'm picking up a replacement cable from my dealer on Tuesday and will definitely be showing him this picture! Thanks for the visual
Mymaverick2021
Steveo
Hilo Hi
They aren't where it is normally adjustable behind the taillights the nut is spot welded, I think another member grinded the weld to level it out and make it adjustable.
( I may be wrong but pretty sure I read that here. )
Either way, mine is level enough to not notice, so happy with it.
You are correct but we shouldn't have to take a grinder to our new truck to make it right
OXHB619
Clayton
XL EB 2.0
I’d throw a level on it, but I don’t own a long one, always had access to one at work, now I’m remote. Hopefully anyone can get them replaced without hassle.
Saul T Knutz
Coastal Virginia
2006 Crown Victoria
Wonder if this has anything to do with "dropping the tailgate" instead of letting it open softly...
Snax
North America
I have never dropped my tailgate, and the cables are too long.
But the truth is that dropping the gate shouldn't cause this problem. The tailgate is very lightweight, and the cables & fittings are strong enough to take a LOT more abuse without stretching.
LSchicago
Lloyd
IL
Ok no idea what the service tech was writing down both stamped numbers on the tailgate assist hook are the same- Work order gives this PN however -
NZ6Z* 6043053*A- Cable-ASY- Tailgate-Support
Tailgate is 100 percent level with new cable- FYI
I noticed a few pics looked like the gate was sagging. Glad they are fixing that.
Bj517
Nc
Lariat
Mine have been too long since day 1. Same as everyone else with an early build. Dropping the tailgate, which I've never been done, shouldn't and wouldn't stretch or pull the cables 3/4" anyway
