SBB
Chip
Matthews
GT350 Shelby
The Ford Maverick assist is built by DeeZee, which sells directly on Amazon. The DeeZee labeling was in one of the pics by the author of this thread.
Anyone know the DeeZee part number that works on the Maverick?
SBB
BDennis
Bruce
So Cal
[/QUOTE]
Note that Installation (step 8) requires the removal of the left tailgate tie-down. They call it the "bottle opener" but is mainly a tie-down that includes the bottle opener feature.
I don't want to lose the tie down so I am installing these:
CrocSee 4 Pack Truck Bed Tie Down Anchors Trailer Cargo Hooks Bolt on D Rings V Rings Heavy Duty
CrocSee Bed Tie Down Anchor
Great $12 solution to losing the tie down
oreomuffin
oreomuffin
CaptainK
Minnesota
Video and install by @oreomuffin
This is the official Ford Accessory Tailgate Assist - Hydraulic :
Update - the bed mat you see in the photo are actually two pieces of this exercise mat taped together with butyl tape.
https://www.menards.com/main/floori...6584011607.htm?tid=2735983253595367499&ipos=6
Ford Maverick Tailgate Assist hydraulic struts & custom bed mat on 2022 Maverick [video] 7655091
You're a gem, @JVolpe Thanks for reposting this.
It seems like most questions have been answered. Happy to do any followup.
Mavhead
Jeremy
Wichita, ks
Nissan versa
When your exercise mat goes bad, you might check out getting some stall mats for horses that you could buy from tractor supply. They are a little bit more heavy duty.
Definitely going to get that closer for my truck tailgate.
HybridOnOrder
Cee
Virginia
Going to be: Maverick XLT, Lux PKG, Moonroof, 360
This is the official Ford Accessory Tailgate Assist - Hydraulic.
I like it!
Pros: No more babying the tailgate down
Neutral: Installation was easy but the last bolt that has to be twisted inside the tailgate was a little tricky. Have a helper.
Cons-ish: A little slowish, not the F150 stock speed, but it’s new so it might get better. You have to remove the bottle opener,hook point.
Don't you lose the ability to put the tailgate partially up??? Like to carry lumber or whatever if you have the tailgate up partially, wouldn't it be hooked to the spot where this damper is attached?
RAMS
Rob
NJ
2020 Kia Sorento SX & 2007 Infiniti M35x
I like it!
Awesome, thanks. More pics of truck bed and how you custom cut that mat. Looks great.
huunvubu
coppell tx
2023 Ford Maverick Hybrid
No you DO NOT lose the ability to put the tailgate partially up.
The damper goes below the lower cable tie point so the upper tie point is still available along with the option to wrap the cable around the lower tie point.
Picture of tie points:
Ford Maverick Tailgate Assist hydraulic struts & custom bed mat on 2022 Maverick [video] Panel in Bed - Left Sid
Ford Maverick Tailgate Assist hydraulic struts & custom bed mat on 2022 Maverick [video] ford maverick tailgate assist hydraulic struts 4
oreomuffin
oreomuffin
CaptainK
Minnesota
It was a process takes a moderate amount of layout skill. Took about 2-3 hours. I made templates out of thin cardboard. Then transferred to the mat. I used a Hultafors Talmeter to measure the internal spacing and transferred that to the mat to cut(box cutter plus sturdy scissors). Started with the middle mat as you can see with the dog picture. Marked the center of the bed and went from there. Next did each side piece and worked toward the cab. The curved parts were the most time-consuming. Sorry, I don't have more process picks. I just happened to be taking pictures of the dog. 😂 The mat is a pretty hefty material. Taped it together with butyl tape. It would take A LOT of force to puncture or tear. I had 3.5 leftover squares. Totaled about $45 in material cost.
Ford Maverick Tailgate Assist hydraulic struts & custom bed mat on 2022 Maverick [video] Mid Progress
Ford Maverick Tailgate Assist hydraulic struts & custom bed mat on 2022 Maverick [video] Bed Complete
sseiler
TN
RAV 4 XSE
Also a good safety device. Don't want a little kid getting a tailgate bonk to the top of their soft heads.
It's cool, but I'm not sure it's necessary. Seems like it might get a little aggravating. This is one of those things I'd probably prefer to take off instead of put on a truck. And if it hits my son on the head maybe it'll knock some sense into him. I've been looking for something for just this purpose. Maybe this is just another perk of having the Mav. And don't worry; he is incredibly hard-headed! :ROFLMAO::LOL::ROFLMAO:
... dang, that's such a lame dad comment. 🤦‍♂️
potatosalad
Los Angeles
Toyota
Question- does it have a bottle opener on both sides of the tailgate and/or can you install the tailgate damper on the right side? I'm assuming you can't because of the mounting bracket.
FirstFord
Massachusetts
VW Jetta
What's it like closing the tailgate? Does the damper offer a lot of resistance?
RAMS
Rob
NJ
Thanks for the pictures and information. Did a great job, and $45 works for me than $150. Cute dog in the pic 👍🏾.
