- First Name
- Jay
- Aug 9, 2024
- Castlegar B.C. Canada
- 2024 XLT 2.0 turbo
- Engine
- 2.0L EcoBoost
Do you flash 5 times or high to low 5 times, ending in low? Just flashing is like a warning to other drivers or low high low high 5 times? Confusing!In the mean time I charged my battery with a trickle charger, bypassing the BCM (directly on the posts; I know this is NOT recommended) and then reset the BCM following the procedures in the manual. Ignition on with engine off, flash high beams 5 times and then press brake pedal 3 times within 2 minutes. Saw the battery light flash on the dash confirming BCM reset. Time will tell how much, if any that helps.
