- Nov 5, 2021
- British Columbia, Canada
- 2022 XLT Maverick Hybrid
- Engine
- 2.5L Hybrid
The two hours a day thing is more for the hybrid, the system just doesn't charge the 12v battery properly (only to 80%), and the only way to do that is if you drive over an hour a day. Ford for some strange reason seems to be unwilling to change this. I can only guess that it's a scam to sell more 12v batteries. Other modern Ford hybrids have the same deep sleep issues, although I don't know if it is a common with other models.Absolutely, I couldn't agree more.
Our Badlands gets driven very little -- typically to the grocery store, which is 6 miles one-way. So 12 miles r/t with the engine started twice and back home the voltage is typically 12.75V+/- (after resting a few hours).
I've read several posts in which the author recommends driving 2 hours a day (as you said). I'm not sure where that comes from. If that's the case and the battery is good, something is wrong with the charging system and/or there is a heavy phantom load.
In any case, even though our charging system seems OK, I connect a BT after it sits for a few days and the voltage decreases to ~12.6V. I wait a while to hook it up because I like to keep an eye on the rate of discharge.
