- Mar 21, 2022
- California
- 23 Maverick Hybrid XLT
- Engine
- 2.5L Hybrid
Exactly what happened to my truck. Came back from a short trip - less than 4 days - and my Maverick was going into deep sleep instantly after ignition off. (Related: wife's Bronco didn't do this. Both are '22 and I assume have similar Battery Monitoring Systems.) I checked the voltage numerous times over 3 days and was annoyed and frustrated, but then I reset the BMS which takes 10-15 seconds, and it's been fine for 3 weeks.
12.5V off is very strong. Somewhere around 12.0 - 11.8 is acceptable as a low range for a normal 12V battery when off.
Actually, both of those values seem a tad high. Maybe .2 to .3V higher than I'd expect. What did you use to measure?
Hey thank you for the insight. I'm just trying to gather as much data as possible on this. I used a voltage meter that I got recommended by a friend, it's in the truck at the moment, so I can't recall the name.
I have tried a few times now since this afternoon to reset the BMS. My understanding is
- turn the key ignition to on, and turn the little Maverick headlight knob on the left hand side clockwise down to the bottom "HI beam" setting five times (and then bring it back to standard auto)
- pump the brake three times immediately afterwards and wait about 10 to 15 seconds
I tried this multiple times and I didn't get any flashing lights or blinking battery icons. I'm going to try again in the morning.
Any tips or advice?
