- First Name
- Mike
- May 3, 2024
- KC Metro area
- 2005 Toyota RAV4, 2024 XLT Hybrid
- Engine
- 2.5L Hybrid
As long as no cat is playing with the keys - the remote has it's own sleep mode on non-movement for the keyless entry.Guessing it's just a time-based function. I don't recall opening the doors recently but it is possible... probably been about 5 days or so since I last messed with the truck (added the quick connect to the power terminals under the hood).
FWIW the hood is left open and an extra key fob is about 10' away hanging on the wall in the garage though I don't know if either of those items would effect the way the truck goes into the sleep mode.
There's no indication or alert or message when it does this, so I assume it's just a time-based function.
Truck still stays awake listening for a fob, but the fob stops broadcasting.
The hood open should be a problem though.
To obtain the 60 min max (25MY I thought someone with Forscan found) before going to sleep, all the sensored openings must appear closed. Not sure how long the timeout is if something is left open. Like eventually a light on because door isn't closed will go ahead and turn off - but is the sensor & module supporting it staying active?
Instructions for finding a parasitic draw are close (by moving the latch) all doors/hood/tailgate that has a sensor on it, then wait the max time (75 & 60) for all modules to turn off - then measure and find the problem if Amp usage is high.
So maybe that's why the Battery Saver for lights is enabled, just as a way turn several things off that the open hood would otherwise have on.
