Mishimoto
Gold Sponsor
Josh
Garnet Valley, PA
2022+ Ford Maverick
Mishimoto is proud to announce a new partnership with Ford Racing Parts: the Mishimoto Performance Intercooler for the 2022+ Ford Maverick, now available exclusively through Ford Racing Parts.
When Ford Racing Parts (formerly Ford Performance) set out to build an upgraded intercooler for the Maverick's performance package, they came to Mishimoto with a clear brief: deliver a significant improvement in cooling efficiency and airflow, without cutting, modifying, or straying from the factory mounting envelope, and make it 50-state legal (EO: D-759-32).
Our engineering team started with the data — a factory intercooler and complete 3D vehicle models supplied by Ford Motor Company — and designed a larger, stronger bar-and-plate core that fits within Ford's original packaging space. TIG-welded cast aluminum end tanks replace the factory's plastic design, giving the unit the strength to handle significantly higher boost pressures.
"Mishimoto had the right engineering disciplines, all the timing was met or exceeded, and to this point has been a success in our minds in terms of support and quality," said Ron Ewert, Ford Racing Engineer.
This project is a great example of what focused collaboration between an OEM performance division and an aftermarket engineering team can produce.
The Mishimoto Performance Intercooler for the 2022+ Ford Maverick is available now, exclusively through Ford Racing Parts.
Get the Full Story: https://www.mishimoto.com/ford-maverick-2022
Carlitos_92
This is great. And I am positive I was one of the ones that said "shut up and take my money" when you guys floated the idea of an intercooler with a non-destructive install...
Apparently I misspoke. Ford cannot have that much of my money. :D
BK007
BK007
OH
I agree. $1k part plus labor at the dealer! And that is a lot of labor to install. Hard Pass.. If I were racing perhaps.. But then I would just do it myself. And it does not fit the Tremor without mods..🤷‍♂️
SteeleMech
2023 Maverick
It's been on sale plenty of times, just like how it's 15% off on Ford Accessories right now
Carlitos_92
That's cool. I'm not gonna knock the product, or mention competitors here, but...
Let's just say hypothetically that I'd be totally willing to take a Sawzall to my front bumper and go to town if I saved $500 buying an intercooler elsewhere.
Chops
Lobo
I’m guessing the labor charge at my dealer would be $1,000+ in addition to the $1,000 part.
However, I have a recall that requires my 2K radiator/fan to be upgraded to 4K no charge. The stock intercooler will need to be removed & reinstalled as part of the no charge recall...
I’m going to ask if Ford will greatly reduce the labor charge to put the upgrade 300T on instead of the OEM. I’d be willing to pay $100-$200 labor - but not the $1,000+
Install instructions
https://performanceparts.ford.com/download/instructionsheets/IS_M-6K775-MAVU_021325.PDF
EffNo50
Central California
Will it fit the Hybrid?
jk :)
Chops
Lobo
jk :)
Your Atkinson engine is normally aspirated (no turbo) and does not need Intercooler.
Normal air is fine for your hybrid. But the turbo on the EB pressurizes air & heats it up. An Intercooler brings the temperature down a bit before it enters the intake.
There are aftermarket air filters for the hybrid that might improve the air flow into your intake. They are much less expensive ($50) than an intercooler ($1000) and something you could change yourself
NIKwithoutaC
Nik
Indiana
1986 Mustang, 2026 Maverick Lobo Sport
I understand that the benefits of this intercooler are largely about being able to run more boost or to have better sustained performance under hot racing/working conditions, but it would have been nice to see the actual dyno test numbers. Grabbing the screen shot below, it looks like maybe baseline was around 239-246 HP, which is what tuned Mavericks get @ the tire, so IDK what's going on there. I see one dyno result in the 290s. Would definitely like to know more about that!
Ford Maverick Mishimoto x Ford Performance 2022+ Maverick Intercooler - Now Available 1784027484149-2h
Tom 71 Maverick 24
Northeast Ohio
Isn't the chief benefit of a larger, more efficient intercooler allowing longer sustained runs without getting heat soak and boost reduction? I'd see this as a good thing for towing in somewhat hilly terrain where you may have 3 or 4 mile climb with 4000 pounds in tow and hot weather - you don't want the engine to be backing down in such a situation.
I'm not convinced that it would initially add HP though it would help in successive runs on a hot day, no doubt.
ice445
Ryan
Utah
24 XLT Tremor
IMO one of the problems is the factory shutters rarely let air over the intercooler in the first place for efficiency reasons. It will definitely help retain peak horsepower in conditions where it's allowed to work, however (like towing as you mentioned). Looks like a very nice unit.
I think though for most Maverick owners, a mod like this would never be noticed. Most people can't even notice going up to 91 octane fuel, so good luck noticing a more efficient intercooler. This is more for the people trying to push the limits of the platform.
F150 2.7 TT user
Kenneth
SE WI
2026 Maverick Tremor, 2017 F150 XL 2.7
I have used a CVF Titan on my F150 for over 5 years now. Generally ICs will not add power, not intended to, rather they keep temperatures under the ECU threshold of knock detection. This allows the best spark timing available. In my F150 the temperature is 115 degrees F inside the intake manifold after the throttle, IAT2. A higher IAT2 will reduce the spark advance and cost as much as 35 HP loss in my 2.7. Extra flow and volume only affect after tuning. The additional cooling from aftermarket ICs is mostly at higher throttle openings when air flow thru the IC is high. At highway cruising the throttle is not open enough to produce much temperature drop. The CVF Titan I have drops the IAT2 temp by near 30 degrees. I have logged this several times to compare with stock IC.
Will I add one to Cathy's Tremor? We will see how ambitions I become. The F150 is easy and has been done several times but the Tremor looks much tighter. The cost is a personal choice, to me the CVF is a good deal in construction and affect.
Grammaton
Ross
Covina, CA
2023 Ford Maverick AWD Lariat BAP 4K CP360+Assist
I tried to order one from Ford Racing/Performance earlier today and my order was canceled. Saying it was not legal to ship to California even thou I see everywhere its 50-state approved with CARB EO#: D-759-32.
