- First Name
- Josh
- Mar 10, 2022
- Garnet Valley, PA
- 2022+ Ford Maverick
- Engine
- Undecided
What makes a performance aluminum radiator actually perform? At Mishimoto, radiators are at the core of what we do — and the question we hear most at the track is: "My temps are creeping up… do I just need to go bigger?" A performance aluminum radiator can absolutely transform your cooling game — more heat rejection, better durability through heat cycles, and the consistency you need when you're pushing hard lap after lap. But here's the thing: raw size doesn't win races. True cooling performance comes down to the entire system — airflow, fan pull, and the engineering inside the core itself: tube construction, fin density, row
configuration, and how it all works together under pressure. A track build has completely different demands than a tow rig or a street car, and choosing the right radiator comes down to matching the design to the vehicle's intended use. The right radiator isn't the biggest one — it's the one engineered for how you drive.
Dive into the full breakdown here: https://www.mishimoto.com/engineeri...-core-thickness-tube-design-airflow-explained
Also, don't miss your chance to win a FREE radiator of your choosing. Enter to win below!
https://www.mishimoto.com/aluminum-radiator-giveaway-april-2026
