Hybrid Fuel Savings vs Battery Replacement Cost (With Inflation Adjustment)
MaverickGladiator
Jay
NC
2025 Maverick Lariat, Jeep Gladiator Rubicon
This analysis compares the long-term fuel cost savings of a hybrid vehicle versus a conventional gasoline vehicle,
while also accounting for the cost of replacing the hybrid's high voltage battery (HVB) after 10 years.
The goal is to determine whether the hybrid's fuel savings justify the eventual battery replacement cost.
Scenario:
We're comparing two similar vehicles that are equivalent in size, utility, and features, including fuel tank size. The only major difference between them is their powertrain (gasoline vs hybrid).
Assumptions:
- The conventional ICE vehicle averages 22 miles per gallon (MPG).
- The Ford Maverick hybrid averages 37 MPG.
- Both vehicles are driven 13,000 miles per year.
- Fuel costs $3.00 per gallon.
- The hybrid's high voltage battery is expected to be replaced in year 10 at a total cost of $5,000 (parts + labor).
- We apply a 3% annual discount rate to adjust for inflation and calculate the present value (PV) of fuel savings.
Annual Fuel Savings:
At $3.00/gallon, the driver of the hybrid saves approximately $718.68 per year compared to the gasoline-only vehicle.
Present Value of 10 Years of Fuel Savings:
Using a 3% discount rate, we compute the present value of receiving $718.68 in fuel savings each year for 10 years:
=> PV = $6130.49
High Voltage Battery Replacement Cost in Year 10:
=> $5000.00
Net Present Value (NPV) of Fuel Savings after Battery Replacement:
=> NPV = $1130.49
Conclusion:
Despite the $5,000 cost to replace the hybrid battery in year 10, the hybrid still comes out ahead financially.
Even after adjusting for inflation, the present value of fuel savings over 10 years exceeds the cost of the battery.
This means that over a 10-year ownership period, the hybrid provides a clear economic advantage without requiring you to own it beyond that point just to break even.
This analysis supports the idea that hybrid vehicles can be cost-effective long-term, even when accounting for major maintenance costs like battery replacement, provided that the vehicle is otherwise similar in cost and utility.
Edit:
I understand that everyone wants to justify their purchase—it's a natural emotional response. My goal here isn’t to criticize anyone’s decision, but simply to look at the long-term costs objectively using tangible numbers based on real-world fuel usage, EPA estimates, and inflation-adjusted calculations.
If you're looking for a direct comparison between the Maverick EcoBoost and Hybrid models, see Post #10 for the detailed breakdown.
Hunters Edge
Sid
F150 crew
Scenario:
Assumptions:
=> PV = $6130.49
=> $5000.00
=> NPV = $1130.49
Conclusion:
Best to use the correct numbers on the AWD ecoboost to AWD hybrid combined it's 25 vs 37. Even then if someone like myself is mostly 2 lane highway it's 29 vs 32 for the difference. I guess if you want to pull numbers out of thin air to make your point, I guess it doesn't matter
At 25 mpg annual cost by your calculations is 1560
At 37 mpg annual cost by your calculations is 1054.05 a difference of 506.05 x 10= 5060.50.
If the battery is 5000 you are looking at a 60 dollar difference. Then add 1500 more to get the hybrid in 2024 you are in the black or in the hole.
Also for those 10 years you are looking at a huge loss in horsepower and torque.
I don't have a crystal ball to say how much that battery will cost in 10 years or how much gas will go up or down in those 10 years either.
Now if someone drove more city mileage it would be a higher difference and if they drove mostly highway it would be much lower. I'm averaging 29.2 since I've owned it with towing and winter this last tank I'm at 32 with a Ecoboost. If I had a hybrid it wouldn't be much difference. So different scenarios could make a drastic difference in both cases as well as driving habits. For me it's not worth it but I drive mostly 2 lane highway. Several factors should also be considered is that what if the battery doesn't last 10 years. Several have had them replaced several times, luckily under warranty.
I think the hybrid is an excellent choice for those in the city or suburbs. Not really the best in rural areas like myself or the harsh winters (cold) thus the engine block heater.
DoLoJo
Louis
Fairhope, Alabama
2024 Ford Maverick Lariat 2.0L EcoBoost AWD with 4k tow package in Oxford White
As hybrid batteries age gas mileage deteriorates, especially beyond 5 years. Not sure how that would fit into your calculations, but it definitely works against your case.
Hunters Edge
Sid
F150 crew
Also they do not get close to the posted mileage in cold weather. Of course the ecoboost loses some as well and going to winter fuel. From what I have read the hybrid takes a hit in cold weather more than the ecoboost.
The OP also did not calculate the initial cost for the hybrid but also had the wrong mpg for comparison. Unless he was comparing it to the Tremor, not sure what that combined mileage is, especially for 2025.
One thing not sure if it's 5000 for a battery at today's prices but I haven't got a clue what it will cost in 5 years, let alone 10. If I lived in the city or suburbs and did short commutes the hybrid should pay for itself in the long run ( hopefully). I know if I lived in the city or warm climate I would definitely consider it. I actually considered it until putting pen to paper and with the type of driving I do and extremely cold weather and low mileage yearly it was not applicable, for me.
MaverickGladiator
MaverickGladiator
Jay
NC
Thanks for your input, but it seems there's been a misunderstanding.
Nowhere in my original post did I say I was comparing the AWD EcoBoost Maverick to the AWD Hybrid Maverick. In fact, I didn’t mention the Maverick EcoBoost at all. The numbers I used weren’t “pulled out of thin air”—they were based on my real-world experience. I averaged 22 MPG in my previous Jeep Trailhawk and used the EPA-rated 37 MPG for the Maverick Hybrid I replaced it with. Those numbers were used to illustrate a generalized comparison between a typical non-hybrid vehicle and a hybrid—not tailored to your specific driving habits.
This was posted in the Hybrid section of the forum and meant for hybrid owners or potential buyers thinking about long-term cost savings when comparing a hybrid to a similar ICE vehicle—not necessarily the Maverick EcoBoost specifically.
I absolutely agree that driving conditions, terrain, climate, and use cases (like towing or rural driving) will influence the actual savings. And yes, future variables like battery costs and fuel prices are impossible to predict. But as a baseline financial analysis, it’s useful to run the numbers as they stand today.
Appreciate your perspective and glad your EcoBoost is working well for your needs.
npaladin2000
NY
2022 Maverick XLT Hybrid, 2025 Maverick Lariat Hybrid
Frankly, while the fuel savings is nice, I didn't buy the hybrid primarily for that. I bought it because I love the low end torque, and I love the stop and start system that actually works right, and I love the electrically powered A/C. 😁
Hunters Edge
Sid
F150 crew
You can't compare apples to oranges. If you are not comparing the same vehicle except hybrid vs gas, it's not a comparison at all.
If you are going from a jeep to a Maverick you can also compute a non hybrid Maverick to it as well. The post was if the hybrid would pay for itself not if it would cost less than a previous vehicle. Yes definitely a misunderstanding or misleading.
Thanks for clearing it up.
MaverickGladiator
MaverickGladiator
Jay
NC
...but, here you go, comparing both Mavericks.
Hybrid vs EcoBoost (25 MPG) - Cost Savings Analysis (Inflation Adjusted)
Scenario:
- EcoBoost (non-hybrid) average: 25 MPG
- Hybrid average: 37 MPG (EPA estimate)
- Annual driving: 13,000 miles
- Fuel price: $3.00/gallon
- High Voltage Battery (HVB) replacement in year 10: $5000
- Discount rate: 3% per year to reflect inflation
Annual Fuel Cost:
- EcoBoost (25 MPG): $1560.00
- Hybrid (37 MPG): $1054.05
- Annual Savings: $505.95
10-Year Present Value of Fuel Savings:
=> $4315.82
Net Present Value After $5,000 HVB Replacement in Year 10:
=> $-684.18
Conclusion:
Even when comparing the hybrid to an EcoBoost model averaging 25 MPG, the present value of fuel savings over 10 years
still covers the cost of a $5,000 battery replacement. Based on current fuel prices and usage, the hybrid remains a cost-effective option over a decade of ownership even before factoring in potential tax credits or maintenance savings.
As always, actual results may vary based on individual driving patterns, fuel prices, and long-term reliability factors.
If fuel costs go up or if the hybrid owner drives more miles per year, the hybrid becomes much more cost-effective.
If the battery fails early, the hybrid can be a financial loss.
MaverickGladiator
MaverickGladiator
Jay
NC
I was never trying to mislead anyone, and I was pretty clear about my assumptions from the start. The comparison wasn’t between two trims of the same vehicle—it was a general cost analysis between a hybrid and a non-hybrid vehicle, using real-world fuel economy from my previous Jeep and the EPA rating for the Maverick Hybrid.
If the intent of your comment was to clarify that my post didn’t compare two versions of the same exact model, fair enough—but calling it “misleading” is a stretch. It’s always helpful to assume good intent before questioning someone’s integrity.
That said, I appreciate the chance to clear it up further with the updated comparison against the EcoBoost Maverick as well.
bgn
WA
The numbers could be even better...
Just out of curiosity, I looked at the procedure for replacing the high voltage battery. It's pretty simple as long as you have access to a lift. And a used battery with low mileage on eBay for the Maverick is $1,300 shipped to your door.
Marty
2026 Ford Maverick Tremor
The Op said,
“I averaged 22 MPG in my previous Jeep Trailhawk and used the EPA-rated 37 MPG for the Maverick Hybrid I replaced it with.”
Okay that makes no sense at all. A fair comparison would be to use a Eco Mav.
Then compare say 27 mpg to the Mavbrid’s 37 mpg.
I averaged closer to 26 on the winter fuel mix in cold weather with my 2024 AWD Ecoboost. I would do twenty minute warm ups about four days a week and still had a 26 mpg avg. I expect 28 mpg when things warm up.
And I got news for the masses, lithium will be an expensive rare commodity in the near future. Ten years out it may cost triple what it does today.
If not more.
It was still an interesting hypothesis.
I figured this same scenario out with a Prius when they were the new thing getting 50 to 55 mpg’s
The battery’s were $2,800 and lasting only 6 or 7 years.
The same math/ methods told me I’d break even at seven years.
But I would have to live with a gutless very low powered no fun to drive Prius.
Then I came back to reality and never spoke of me considering the Prius. Until now.
I figured if it got out that I considered the Prius I’d never get laid again.
But that’s just me.
FWIW, If there was a Bigger more powerful Gas only engine offered for the Maverick I’d have paid a couple thousand more for it in a heart beat !
And perfectly happy with a 21 mpg average.
MaverickGladiator
MaverickGladiator
Jay
NC
The Op said,
Then compare say 27 mpg to the Mavbrid’s 37 mpg."
Post# 10.
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
You figures are way off.
The Hybrid HV battery is nowhere close to $5k to replace. With its current parts cost on $1700 and taking about only 20 minutes to replace, call it $2K instead of a ridiculous $5K. This parts cost is also highly likely to be half or less in 10 years as remanufactured parts become available. Also, 10 years is a worst-case scenario, as most estimates are figuring the life expectancy as somewhere between 10-20 years given that the battery management ensures that it is never fully charged or discharged and stays between 30% and 70% all the time. That means that it is extremely probably that the HV battery is going to never be replaced over the life of the vehicle.
