- First Name
- Peter
- Sep 20, 2022
- Vancouver Island BC Canada
- 1987 GMC S15 4x4
- Engine
- 2.5L Hybrid
True, the Mavericks hybrid battery is quite small, and nowhere near $5000 to replace. I'm guessing future battery technology will make it even less than $2000. The fact there's thousands of hybrid taxis in use should tell you something about hybrid cost effectiveness. Hybrids also have no alternator, starter or serpentine belts or turbocharger, also because of the region braking, will require much less brake pad/rotor replacement, (not to mention the simplicity of the Hybrid transmission) these are all fairly costly maintenance items. That fact also has to be factored into the equation.You figures are way off.
The Hybrid HV battery is nowhere close to $5k to replace. With its current parts cost on $1700 and taking about only 20 minutes to replace, call it $2K instead of a ridiculous $5K. This parts cost is also highly likely to be half or less in 10 years as remanufactured parts become available. Also, 10 years is a worst-case scenario, as most estimates are figuring the life expectancy as somewhere between 10-20 years given that the battery management ensures that it is never fully charged or discharged and stays between 30% and 70% all the time. That means that it is extremely probably that the HV battery is going to never be replaced over the life of the vehicle.
