Hybrid Fuel Savings vs Battery Replacement Cost (With Inflation Adjustment)
Tim d
Alpena
Ram
This analysis compares the long-term fuel cost savings of a hybrid vehicle versus a conventional gasoline vehicle,
while also accounting for the cost of replacing the hybrid's high voltage battery (HVB) after 10 years.
The goal is to determine whether the hybrid's fuel savings justify the eventual battery replacement cost.
Scenario:
We're comparing two similar vehicles that are equivalent in size, utility, and features, including fuel tank size. The only major difference between them is their powertrain (gasoline vs hybrid).
Assumptions:
- The conventional ICE vehicle averages 22 miles per gallon (MPG).
- The Ford Maverick hybrid averages 37 MPG.
- Both vehicles are driven 13,000 miles per year.
- Fuel costs $3.00 per gallon.
- The hybrid's high voltage battery is expected to be replaced in year 10 at a total cost of $5,000 (parts + labor).
- We apply a 3% annual discount rate to adjust for inflation and calculate the present value (PV) of fuel savings.
Annual Fuel Savings:
At $3.00/gallon, the driver of the hybrid saves approximately $718.68 per year compared to the gasoline-only vehicle.
Present Value of 10 Years of Fuel Savings:
Using a 3% discount rate, we compute the present value of receiving $718.68 in fuel savings each year for 10 years:
=> PV = $6130.49
High Voltage Battery Replacement Cost in Year 10:
=> $5000.00
Net Present Value (NPV) of Fuel Savings after Battery Replacement:
=> NPV = $1130.49
Conclusion:
Despite the $5,000 cost to replace the hybrid battery in year 10, the hybrid still comes out ahead financially.
Even after adjusting for inflation, the present value of fuel savings over 10 years exceeds the cost of the battery.
This means that over a 10-year ownership period, the hybrid provides a clear economic advantage without requiring you to own it beyond that point just to break even.
This analysis supports the idea that hybrid vehicles can be cost-effective long-term, even when accounting for major maintenance costs like battery replacement, provided that the vehicle is otherwise similar in cost and utility.
Edit:
I understand that everyone wants to justify their purchase—it's a natural emotional response. My goal here isn’t to criticize anyone’s decision, but simply to look at the long-term costs objectively using tangible numbers based on real-world fuel usage, EPA estimates, and inflation-adjusted calculations.
If you're looking for a direct comparison between the Maverick EcoBoost and Hybrid models, see Post #10 for the detailed breakdown.
22 mpg? I consistently get close to or over 30 mpg with our ecoboost maverick.
MaverickGladiator
MaverickGladiator
Jay
NC
2025 Maverick Lariat, Jeep Gladiator Rubicon
You figures are way off.
The Hybrid HV battery is nowhere close to $5k to replace. With its current parts cost on $1700 and taking about only 20 minutes to replace, call it $2K instead of a ridiculous $5K. This parts cost is also highly likely to be half or less in 10 years as remanufactured parts become available. Also, 10 years is a worst-case scenario, as most estimates are figuring the life expectancy as somewhere between 10-20 years given that the battery management ensures that it is never fully charged or discharged and stays between 30% and 70% all the time. That means that it is extremely probably that the HV battery is going to never be replaced over the life of the vehicle.
Thanks for the additional context that's actually helpful.
I used $5,000 as a conservative placeholder to represent a *worst-case scenario* that includes both parts and labor, based on anecdotal estimates people have floated for full HV battery replacement outside of warranty. But you're right, current part prices are significantly lower, and with the simplicity of the Maverick's battery swap, the cost may ultimately end up closer to $2,000 or less.
Also, fair point about battery longevity. The 10-year figure I used was intentionally cautious. If the battery lasts 15, 20 years, or never needs replacement at all, the long-term savings of the hybrid become even more favorable.
Appreciate you sharing those insights. My original intent was to help others see the big picture through objective, conservative math, so comments like yours definitely help sharpen the discussion
Skrizzi
Detroit
If we're comparing to the ecoboost, you're probably replacing the turbo at the same time you'd be replacing the HV battery on the hybrid. Those costs if you go through a dealer are probably similar.
MaverickGladiator
MaverickGladiator
Jay
NC
Interesting. I did not take that into consideration. I never owned a forced induction vehicle. Do Turbos ever need to be replaced?
Skrizzi
Detroit
Oh yeah, and they can be pricey. The Ecoboost shouldn't be too bad but on some integrated manifold vehicles it can be 5k to replace turbos. They have bearings that wear over time and can cause oil leaks into the exhaust causing oil burning. Highly dependent on maintenance and how the vehicle is taken care of, I think most people would see a turbo replacement between 100-150k miles.
Bob zimmerman
Northern <MN
25’ Maverick XLT hybrid AWD
Let’s use my actual experience as an example instead of made up numbers.
I owned a Prius for 18 years. Drove it to the junk yard with 186k on the odometer. The hybrid battery was still working. I was still getting 38 mpg on the vehicle. Less than new but still good.
That is a real life case study of a hybrid. I essentially got that car for almost free if I compare it to an ICE vehicle.
Hybrids pay for themselves over time.
Tim d
Alpena
Ram
They are supposed to last the life of the vehicle. I know that's subjective.
Cherokee
Roflmao, Re manufactured lithium yeah right.
After market cells ha ha ha, those cheap Chinese cells burn down houses and cars.
Quality cells only come from a few companies.
MaverickGladiator
MaverickGladiator
Jay
NC
"Made up numbers"???
Greg F
Greg
Southern Ontario, Canada
2025 Ford Maverick Lariat AWD Hybrid
Hi,
I've been lurking around the forums for a bit. I got my 2025 Lariat Hybrid back on January 14.
The hybrid is saving money at $3.00/gallon. However, that same gallon costs $4.00 USD in Canada. On April 1st, our carbon tax is getting a substantial boost. Gas will probably be in the $4.50 USD range as of April Fools Day.
710-oil-614
Cal
2025 Hybrid AWD Lariat
The Op said,
“I averaged 22 MPG in my previous Jeep Trailhawk and used the EPA-rated 37 MPG for the Maverick Hybrid I replaced it with.”
Okay that makes no sense at all. A fair comparison would be to use a Eco Mav.
Then compare say 27 mpg to the Mavbrid’s 37 mpg.
I averaged closer to 26 on the winter fuel mix in cold weather with my 2024 AWD Ecoboost. I would do twenty minute warm ups about four days a week and still had a 26 mpg avg. I expect 28 mpg when things warm up.
And I got news for the masses, lithium will be an expensive rare commodity in the near future. Ten years out it may cost triple what it does today.
If not more.
It was still an interesting hypothesis.
I figured this same scenario out with a Prius when they were the new thing getting 50 to 55 mpg’s
The battery’s were $2,800 and lasting only 6 or 7 years.
The same math/ methods told me I’d break even at seven years.
But I would have to live with a gutless very low powered no fun to drive Prius.
Then I came back to reality and never spoke of me considering the Prius. Until now.
I figured if it got out that I considered the Prius I’d never get laid again.
But that’s just me.
FWIW, If there was a Bigger more powerful Gas only engine offered for the Maverick I’d have paid a couple thousand more for it in a heart beat !
And perfectly happy with a 21 mpg average.
20 minute warm ups????
Suzukiridr14
Frank
Sarasota Florida
Best to use the correct numbers on the AWD ecoboost to AWD hybrid combined it's 25 vs 37. Even then if someone like myself is mostly 2 lane highway it's 29 vs 32 for the difference. I guess if you want to pull numbers out of thin air to make your point, I guess it doesn't matter
At 25 mpg annual cost by your calculations is 1560
At 37 mpg annual cost by your calculations is 1054.05 a difference of 506.05 x 10= 5060.50.
If the battery is 5000 you are looking at a 60 dollar difference. Then add 1500 more to get the hybrid in 2024 you are in the black or in the hole.
Also for those 10 years you are looking at a huge loss in horsepower and torque.
I don't have a crystal ball to say how much that battery will cost in 10 years or how much gas will go up or down in those 10 years either.
Now if someone drove more city mileage it would be a higher difference and if they drove mostly highway it would be much lower. I'm averaging 29.2 since I've owned it with towing and winter this last tank I'm at 32 with a Ecoboost. If I had a hybrid it wouldn't be much difference. So different scenarios could make a drastic difference in both cases as well as driving habits. For me it's not worth it but I drive mostly 2 lane highway. Several factors should also be considered is that what if the battery doesn't last 10 years. Several have had them replaced several times, luckily under warranty.
I think the hybrid is an excellent choice for those in the city or suburbs. Not really the best in rural areas like myself or the harsh winters (cold) thus the engine block heater.
I didn't hear of anyone having the hybrid battery replaced, only the 12V battery. Also on Ebay, the hybrid batterys sell for $1000-$1300 that were removed from wrecks.
MaverickGladiator
MaverickGladiator
Jay
NC
Hi,
For sure. The higher the cost of fuel, the more you drive, the savings becomes more substantial. And when/if the Hybrid Battery needs to be replaced, I've calculated that the cost savings of owning the hybrid will still out weigh the eventual cost of battery replacement. You will still be definitely ahead.
This is primarily why I created this thread. Most of us primarily bought the Ford Maverick due to its price compared to similar vehicles. Sure, the price of the Ford Maverick has substantially jumped up in price from 4 years ago, but what vehicle hasn't? I just wanted to crunch the numbers because I do plan to keep this vehicle long term. Just like my Jeep Gladiator.
Cherokee
Yeah I know I’m wasting fuel but on those cold single digit and below 20 F mornings I really Reeeaaallly like my seat and steering wheel all toasty warm.
You Mavbrid guys are lucky. You get to warm your cab with Lectricity :’P
I click that key fob for fifteen minutes and five minutes later I click it again for a second fifteen minutes.
Yep, come warmer weather 28-29 mpg is in easy reach.
I’ll never see 30-32 mpg average out of my Eco. I climb multiple times every time I come down to go to town.
